99 dodge ram wont start..help.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2013, 10:13 AM   #1
offroad86b2
offroad86b2's Avatar
Send a message via AIM to offroad86b2
Default 99 dodge ram wont start..help..
the other day i was driving it,about 50 miles later it started bogging out on I75. i pulled over and couldn't get the rpm's over 1500. had it towed home,ran a scanner on it No Codes... fuel pressure 49 psi,new coil,pickup coil,cap n rotor, plugs n wires, crank sensor, tp sensor and computer..got me stumped. Anyone got any idea's?????
offroad86b2 is offline   Reply With Quote
Old February 22nd, 2013, 11:07 AM   #2
masterbeatty
masterbeatty's Avatar
Check the volume of fuel? My expedition put put out pressure but when u hit the button to fill a 16oz bottle it took forever
Old February 22nd, 2013, 11:18 AM   #3
Toyfish
Toyfish's Avatar
Check for a plugged converter if the fuel volume is good
Old February 22nd, 2013, 01:42 PM   #4
offroad86b2
it fires up here n there but only for a second..i just put a new cat on 6 months ago,fuel volume is great...filled a 24oz in no time..
Old February 22nd, 2013, 07:49 PM   #5
frdboy
frdboy's Avatar
I would still check backpressure or pull the O2 and see if it will start. Also check for water in the fuel.
Old February 23rd, 2013, 08:46 AM   #6
offroad86b2
ok,no water in the fuel,did a compression test they are all 65-75psi,im about done!! lol
Old March 8th, 2013, 11:15 PM   #7
Ajhawk
Ajhawk's Avatar
Hmmm, sounds like the cat is plugged, or possibly a dirty fuel filter? Don't have any pissed off ex's do you? :/
Ajhawk is offline   Reply With Quote
Old March 8th, 2013, 11:23 PM   #8
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
plugged cat.. had the same problem..
bigjay is offline   Reply With Quote
Old March 11th, 2013, 10:58 PM   #9
moparhorse
moparhorse's Avatar
Does it have a good blue spark to it and also does it ever backfire through the carb or exhaust?
moparhorse is offline   Reply With Quote
Old July 31st, 2013, 06:33 AM   #10
TheDodgeGuy
PR MTU 4X4
TheDodgeGuy's Avatar
Compression also sounds a little low. My 360 (149k) was around 160 psi for compression IIRC
TheDodgeGuy is offline   Reply With Quote
Old July 31st, 2013, 01:48 PM   #11
redramman
redramman's Avatar
yes those compression readings are way to low.Did you crank engine about 5 revolutions with tester on? Sounds like my truck when Cat was plugged .Its possible plugged cat could make compression low by restricting engine flow... not enough air can get in less air to compress ...low reading(I think). at the time of cat the other problem was crankshaft position sensor located on front of engine I think I had damaged it or knocked ot out of position while working on something else.
redramman is offline   Reply With Quote
Old July 31st, 2013, 01:52 PM   #12
redramman
redramman's Avatar
now that I think about it the Crank position sensor threw a fault code .
Old July 31st, 2013, 02:11 PM   #13
redramman
redramman's Avatar
http://www.summitracing.com/parts/cto-9666 I was trying to find the Y pipe without Cat I think Dynoflow makes it.
Old July 31st, 2013, 02:16 PM   #14
redramman
redramman's Avatar
Oh yea BATMAN the Joker put this OLD thread here!!!!!!!!!!!!!!!
Page generated in 0.23061 seconds with 65 queries
