air compressor/plasma cutter question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2013, 12:52 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default air compressor/plasma cutter question
http://www.millerwelds.com/products/...p?model=M13811
i have been thinking about getting a plasma cutter for a while. seen this one and have a friend who has it and it worked well and seemed big enough for my needs. question is will my air compressor be enough? i have never understood how to tell how long you can use something b4 you have to stop and let air rebuild.
plasma says 5 SCFM (146 L/min) at 90 PSI MIN (621 KPa) 120 PSI MZX (828 kPa)
my compressor i have now is a 33 gallon 6hp that does 8.6 scfm at 40psi and 6.4 scfm at 90 psi. how long could i use the cutter b4 i would have to take a brake and let air rebuild.
if this compressor is to small the i will have to get a larger one b4 i spend the coin for the cutter just dont want to have a toy i cant use. thanks guys for any info.
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old February 21st, 2013, 08:31 PM   #2
Tab
Tab's Avatar
If its a 6hp 33 gallon you will be fine. I ran a CNC plasma system with cuts that are far longer than you're going to be doing by hand on the same size system for a while because my big one was getting rebuilt.
Old February 21st, 2013, 09:01 PM   #3
I only had 1 220v circuit in my garage, so had to let the 60 gallon compressor build a tank, then switch the plug to use the plasma. I never really have a problem with it, just the tank full of compressed air without the compressor on never ran low....but I never used mine for cutting really large shapes out of plate, more like cutting brackets of axles, or cutting out smaller brackets, etc. I would think that compressor will be fine.
Old February 21st, 2013, 09:35 PM   #4
jaysusr
jaysusr's Avatar
What tab said. My hand cuts are so short , you won't deplete the air faster than you the operator have to stop to reset your guides or cutting position. Roll with it.
Old February 21st, 2013, 10:18 PM   #5
CHEROKEEMUDMAN01
mellow yellow
ok thank you guys just didnt want to buy it and be stuck with 6" cuts at a time.
Old February 21st, 2013, 10:55 PM   #6
jaysusr
jaysusr's Avatar
Dude, having a plasma opens up a whole new world of fab. U won't be sorry.
Old February 24th, 2013, 08:00 AM   #7
CHEROKEEMUDMAN01
mellow yellow
agree i go through about 20 cut off wheels a weekend doing fab stuff in garage. plus the mess and crap in the air they make it would be worth every penny
Old February 24th, 2013, 09:31 AM   #8
Suta99
Suta99's Avatar
You are using the wrong cutoff wheels. We build a large woodstove from 1/4 and started with a 4x8 sheet and started with a 6" .045" wheel and when I was done it was still larger than the 5" ones I usually use.
Old February 24th, 2013, 10:01 AM   #9
beertestr
Buy the plasma. You won't be sorry. I have a 3/8" capacity unit and have made those cuts several times. I do 1/4" all the time, nice clean cuts once you get the hang of it.
Sent from my DROID BIONIC using Tapatalk 2
beertestr is offline   Reply With Quote
Old February 24th, 2013, 06:11 PM   #10
CHEROKEEMUDMAN01
mellow yellow
i use the 41/2 ones from lowes and home depot. do alot of floor pan repairs and it just chews through wheels and i can make them last not like my friend who if u give him the grinder its gone in 10 sec lol
Page generated in 0.26331 seconds with 53 queries
