towing my 87 dodge raider - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2013, 03:27 PM   #1
Raging_Raider
Default towing my 87 dodge raider
i am about to buy a 87 dodge raider v6 5 speed with a broken timing belt. ( don't worry the engine isn't shot, it is a non interference engine)
but my issue is that i have to tow the damn thing 166 miles back home.
what i need to know is, how do i tow it. the 4wd shifter has a neutral.. so wouldn't that mean it is tow-able on a car dolly? i would just throw it in both tranny and 4wd into neutral and head home?
i was also told to be safe i would just put the front tires on the dolly and remove the rear drive line completely and it would not do a damn thing wrong to it. that seems to be the safest way but it is just a little extra work to be done.
but what i am getting at is, i need wisdom on how to tow it.
also it needs tires and rims can any one help me with what other tires from other rigs will fit and work.
please and thank you
Raging_Raider is offline   Reply With Quote
Old March 11th, 2013, 11:16 PM   #2
moparhorse
moparhorse's Avatar
Trans in park so the tailshaft wont spin and t-case in neutral. If it were me i would remove the rear shaft. T-cases dont lube unless they are in gear. Did it make it home ok?
moparhorse is offline   Reply With Quote
Page generated in 0.15974 seconds with 29 queries
