TJ: Nv3550 / ax15 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2013, 05:19 AM   #1
Hooperdog
OllllO
Hooperdog's Avatar
Default Nv3550 / ax15
looking at a few TJ's for sale, how can I tell if it has an ax15 or a nv3550 trans? Is there a tag on them or can I tell by appearance? thanks
Hooperdog is offline   Reply With Quote
Old February 20th, 2013, 07:50 AM   #2
RADRICK
RADRICK's Avatar
FYI ax-15 97 up till 2000. 2000 and up nv3550. Unless they were swapped.
Old February 20th, 2013, 09:52 AM   #3
bdd1469
bdd
bdd1469's Avatar
^^ this
The 3550 is a little stronger and has a lower first gear. The ax 15 is more common and much easier to get parts for if you damage it.
Old February 20th, 2013, 01:26 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Take a look at Novak's site for the AX15 and NV3550 for some pics and info. Easiest I know of, and I think reasonably fool proof is looking at the output shaft if its flush or not (figuring you're buying just a trans and there's not a t-case on it).
http://www.novak-adapt.com/knowledge/ax15.htm
http://www.novak-adapt.com/knowledge/nv3550.htm
NV3550: Spline count for the input shaft is 10 splines x 1-1/8" diameter. The output shaft has 23 splines and is flush with the rear face of the transfer case adapter flange.
AX15: The 4wd version of the Jeep AX15 has a 23 spline output shaft for connecting to the transfer case input shaft. This shaft protrudes about 1/2" past the rear face of the transmission.
Make sure you don't pick up an AX5, it should have 23 spline output, not 21 like on an AX-5.
Old February 21st, 2013, 06:04 AM   #5
Hooperdog
OllllO
Hooperdog's Avatar
thanks
Old February 21st, 2013, 01:48 PM   #6
Ebs
An AX15 has a big ole intermediate plate sandwiched between the case halves. The NV3550 does not.
Page generated in 0.21059 seconds with 41 queries
