cummins hagglunds swap - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2013, 01:52 PM   #41
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Originally Posted by jaysusr View Post
Doesn't this have dual batteries? Or is it one single 24vbatt? If so, can't you just run a one batt starter circuit?
Dual batteries, yes you can tap off of a certain spot to get 12v.
sbcrichie is offline   Reply With Quote
Old February 27th, 2013, 01:55 PM   #42
HVYRTFT
Reed my teef
HVYRTFT's Avatar
What does your customer do with something like this?
Old February 27th, 2013, 10:26 PM   #43
kkodet
kkodet's Avatar
Originally Posted by sbcrichie View Post
I thought on gasser they run manifold vacuum, more throttle equals less manifold vacuum on a gasser. I also thought they ran cable operated vacuum modulators on diesels. And in this case transgo puts the vacuum modulator inside the pan so you would have to get a cable in there somehow. I also questioned transgo on the modulator to find out if it was a 400 modulator and they said no it was a special one for their application. I'm not saying it can't be done but I wasn't comfortable with it on this vehicle and owner will be happier not shifting it all the time.
You are right, I said that backwards, but on the cummins it is a simple gear drive powersteering/vacuum pump combo, nothing more. If it requires a varying rate of vaccum for shifting I don't know. I know they work, and never really measured it to figure out. But the transgo thing sounds cool too.
Old February 28th, 2013, 07:27 PM   #44
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
he has a cabin he built out in the sticks somewhere in canada. it is a ways off the main road so he uses this to get back there.
yea the vacuum varies to control the pressure in the trans. i found out the hard way on a fmvb in my 400, i didnt run a vacuum modulator so the pressure was always maxed out in it and it was blowing out valves and retainers pins and clips in the valve body. so i am a little gun shy on trying to rig something up on this. gonna use a baumann controller a custom torque converter built by precision, and a full rebuild on the trans with normal upgraded components.
Old March 17th, 2013, 11:01 PM   #45
green50gt
Got rocks?
green50gt's Avatar
Any updates?
I heart Jeeps
green50gt is offline   Reply With Quote
Old March 18th, 2013, 07:25 AM   #46
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I did get hydro pump moved, and mounted trans cooler, also got trans rebuilt and got new torque converter here. I got swamped at the shop with other things to do so haven't been able to work on it much in the last two weeks.
Old March 25th, 2013, 08:08 AM   #47
caveman
GeoDude
caveman's Avatar
How am I just now finding this!!! Was this the one that sits on congress at that warehouse?
Old March 25th, 2013, 12:57 PM   #48
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yes I think it was sitting there for awhile
Old March 25th, 2013, 01:06 PM   #49
hondadirtracer
Skymaster
hondadirtracer's Avatar
I know 4bt cummins are used in smaller heavy equipment and those systems are normally 24 volt. Why couldn't you just use a starter from one of those like this one http://www.amazon.com/Dresser-510B-D.../dp/B0081SBTRG ?
hondadirtracer is offline   Reply With Quote
Old March 25th, 2013, 08:49 PM   #50
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
the destroked adapter plate uses a 6.0 power stroke starter
Old March 25th, 2013, 09:58 PM   #51
hondadirtracer
Skymaster
Oh ok. I just reread the original post and I missed that part.
Old March 27th, 2013, 03:44 PM   #52
caveman
GeoDude
caveman's Avatar
so is this thing going out to roush when done.
Old March 27th, 2013, 03:56 PM   #53
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Cool project.
One possibility for trans control is the Rossler Little Black Box. I stumbled on it while looking for MVB for a 4L60E. I've never used one, but they offer for 4L60E and 4L80E. It's a plug-in manual controller, so you don't gut the trans, just manually control solenoids. But I'm guessing cost isn't big object.
http://www.rosslertrans.com/4L80E.htm
Old March 27th, 2013, 08:37 PM   #54
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I doubt it, unless you can talk the owner into taking it. If he does you can ride in the back box
Old March 27th, 2013, 08:38 PM   #55
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Originally Posted by JohnnyJ View Post
Cool project.
Good to know i have never heard of that one before.
Old March 28th, 2013, 08:53 AM   #56
caveman
GeoDude
caveman's Avatar
Is that going to be the rape room? What kinda stuff you gonna fab up for that? lol
Old March 28th, 2013, 10:23 AM   #57
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I will build you a special sit and spin seat.
Old September 24th, 2013, 08:38 PM   #58
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
well finally getting back on this project. time to get it out of my shop. recruited some help from my dad to hurry up and knock it out. all of the wiring is done including Ushift trans controller. all fuel and transmission lines done, all coolant lines done. serp belt figured out and alt mounted. most of the exhaust and turbo plumbing done, just gotta finish up the air cleaner and pipe and make some sort of box manifold to go from turbo intake to air cleaner pipe, tight fit between front of turbo and oil filter. made turbo relocation thingy mabob. hopefully fire the engine up this week. still got to build drive shafts but think we have them figured out.
Old September 24th, 2013, 08:49 PM   #59
BlackBetty97
We Like it Loud
BlackBetty97's Avatar
Just a thought for your turbo intake from air cleaner clearance issue. The Cummins ISX uses a boot that I believe would fit into your location there (not sure that pipe dimensions would be the same). I can take a look in the shop tomorrow and see if I can come up with a part # for reference. I know that there are a few applications though that require a very tight turn from the air cleaner plumbing to the turbo.
BlackBetty97 is offline   Reply With Quote
Old September 24th, 2013, 08:53 PM   #60
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea I was wondering about one of those too but wasn't sure were to look for one. it is a 3" on the turbo and im using a 3" pipe
Page generated in 0.79948 seconds with 83 queries
