cummins hagglunds swap - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2013, 06:51 PM   #21
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Originally Posted by sbcrichie View Post
This is a 24v system so I need to use a 12v starter on 24v system opposite of what petersons did but maybe it would still work I'll have to look at what they did.
Gonna try the trans go manual kit
They were running a 24V winch and everything else was 12vdc including their starter what more do you need?
ckupq is offline   Reply With Quote
Old February 21st, 2013, 07:09 PM   #22
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
they had a 12v system on their truck and a 24v winch. i have a 24v system on this thing and need to run a 12v starter. its a different scenario. i may be wrong i havent researched it yet but i believ going from 12 to 24 is different than going from 24 to 12. but like i said i havent got to the wiring yet so i havent researched it yet.
sbcrichie is offline   Reply With Quote
Old February 21st, 2013, 07:11 PM   #23
capone
capone's Avatar
Subscribed. Cool Project.
capone is offline   Reply With Quote
Old February 21st, 2013, 07:26 PM   #24
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
got the drivetrain mocked up, not much room lol. gonna half to run a 4x4 output shaft and make my own bushing and seal housing to i can shorten trans up. the front driveshaft runs the hydro pump and fan off of the crank pulley, i mocked up this shaft but the angles are pretty severe so today i pulled engine back out and moved fan forward and moved hydro pump forward a couple inches and to the pass side a couple inches to get angles more exceptable.
Old February 21st, 2013, 07:50 PM   #25
tator
tator's Avatar
Hey if you need a hand give me a call, and if you need anything made I'm bored as hell at work.
tator is offline   Reply With Quote
Old February 21st, 2013, 07:57 PM   #26
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
ok sounds good. im gonna take a shot at machining the extension housing myself but if i run into trouble maybe ill have ya draw it up and cnc it.
Old February 21st, 2013, 08:32 PM   #27
green50gt
Got rocks?
green50gt's Avatar
Wow this is cool!
I heart Jeeps
green50gt is offline   Reply With Quote
Old February 21st, 2013, 08:39 PM   #28
kkodet
kkodet's Avatar
yes thats what ive been thinking too but after doing some research ive heard both stories some last forever and some work three times. if it was mine yea i would put 24 too it and see what happens but since its a customer that travels out in the boonies with it it would be bad for me if he got stranded cause starter crapped out.
All the "crapped out" stories I'm familiar with are when guys are using 50 plus year old starters, that eventually fail anyways. I've run 12 volt on 6 volt starters for years on my 48 Case tractor, 53 Chevy pickup, 28 model A, 55 Imperial, 48 CJ2A and a few others. Never had a problem with any of em.
Old February 22nd, 2013, 03:26 PM   #29
bacongrease
Am i still a Noob?
bacongrease's Avatar
24V on a 12V DC motor wont damage the motor under normal use.
However if exteneded cranking is needed, the motor will heat up very quickly which kills DC motors.
Personally i would do what it takes get 12V to the starter if it were a customers project.
bacongrease is offline   Reply With Quote
Old February 26th, 2013, 07:21 PM   #30
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
well i went to order the transgo full manual kit and realized you have to run a vacuum modulator so i guess that is out seeing as diesels dont make vacuum. So i think im gonna get the baumann controller. i think customer will be happier anyway with the controller so he wont have to shift it all the time.
Old February 26th, 2013, 07:30 PM   #31
Windsorf350
Rusty Racing
Windsorf350's Avatar
If you want to run the mvb could you just run a vacum pump like they run on the old ford diesles?
Windsorf350 is offline   Reply With Quote
Old February 26th, 2013, 07:38 PM   #32
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea you can but you have to figure out how to regulate the vacum with throttle position, it can be done but i dont think i want to fart with it. its only 500$ for the controller and its 250$ for the mvb so i think 250 is well worth not having to shift it all the time. I was honestly worring about someone driving it in 4th gear all time, it sounds like he lets his kids and buddies drive it.
Old February 26th, 2013, 07:42 PM   #33
Windsorf350
Rusty Racing
O i didn't even think about that part. which trans controller are you going to run?
Old February 26th, 2013, 07:52 PM   #34
kkodet
kkodet's Avatar
A stock dodge ram power steering/vacuum pump bolts to a 4bt, why not go that way? I also have an external belt driven vacuum pump setup from a 4bt I'd sell if you are interested.
Old February 26th, 2013, 08:23 PM   #35
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
well the vaccum pump just makes a set amount of vacuum. the vacuum modulator on the tranny modulates fluid pressure according to throttle position. so you have to regulate the vacuum so it applies correct pressure for load on tranny.
Old February 26th, 2013, 08:25 PM   #36
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
lots of people recamend compushift controller but its 1200. bauman makes a controller for 500$ and i honesly like the guy at bauman better after talking to him on the phone. gonna have to get a dc to dc 24v to 12v converter to run the trans controller.
Old February 26th, 2013, 08:48 PM   #37
kkodet
kkodet's Avatar
The engine driven vacuum pumps create more vacuum the higher the RPM, just like a gasser motor will. In the stock bread van 4bt/TH400 setups thats what they used.
Old February 26th, 2013, 08:52 PM   #38
jaysusr
jaysusr's Avatar
Doesn't this have dual batteries? Or is it one single 24vbatt? If so, can't you just run a one batt starter circuit?
Old February 26th, 2013, 08:59 PM   #39
hillbilly2007
hillbilly2007's Avatar
I want one of these. I have no reason to have it, other than to say i had one lol
hillbilly2007 is offline   Reply With Quote
Old February 27th, 2013, 12:45 PM   #40
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I thought on gasser they run manifold vacuum, more throttle equals less manifold vacuum on a gasser. I also thought they ran cable operated vacuum modulators on diesels. And in this case transgo puts the vacuum modulator inside the pan so you would have to get a cable in there somehow. I also questioned transgo on the modulator to find out if it was a 400 modulator and they said no it was a special one for their application. I'm not saying it can't be done but I wasn't comfortable with it on this vehicle and owner will be happier not shifting it all the time.
Page generated in 0.48602 seconds with 83 queries
