vapor lock symptoms - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2013, 07:53 PM   #1
chevotass
chevotass's Avatar
Default vapor lock symptoms
still chasing my motor bug.
now im wondering if its vaporlock .
what are the normal symptoms. will the motor still idle and run?
Old February 19th, 2013, 07:54 PM   #2
Toyfish
Toyfish's Avatar
Possibly would idle does it idle rough?
Old February 19th, 2013, 08:02 PM   #3
chevotass
chevotass's Avatar
nope. idles great. runs great for a while. then all of a sudden it loses all power when into giving it throttle.
Old February 19th, 2013, 08:07 PM   #4
jerm97xj
I fixed it!!!
jerm97xj's Avatar
How do the plugs look?
jerm97xj is offline   Reply With Quote
Old February 19th, 2013, 08:38 PM   #5
in2deep
Hole tester
fuel pressure gauge will tell you fast
Old February 19th, 2013, 08:40 PM   #6
GREASYHANDS
GREASYHANDS's Avatar
Vapor lock happens under high heat.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 20th, 2013, 03:17 PM   #7
hotstuff
sounds like a accel. pump
hotstuff is offline   Reply With Quote
Old February 20th, 2013, 06:36 PM   #8
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
x2.
My Jeep would run great when I first started it up, as time went by wheeling around and the fuel heated up, it would start missing, spittering/sputtering like I was running out of gas. Then after it got so hot it would die, once it cooled down it start up and would run fine. I had to reroute the lines away from my headers to fix the issue.
Old February 22nd, 2013, 09:47 AM   #9
Outdoors
Field Repairs
Outdoors's Avatar
If you have vapor lock the bowl will not be full of fuel. Yes, it will idle fine.
Outdoors is offline   Reply With Quote
Old February 22nd, 2013, 09:48 AM   #10
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
not always
Old February 22nd, 2013, 09:58 AM   #11
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
I had an S10 that would do something like that. It would get a bubble trapped behind the fuel injector if the motor backfired. A couple bounces off the rev limiter would clear the bubble and make it run normal again.
ckupq is offline   Reply With Quote
Old February 22nd, 2013, 10:03 AM   #12
Outdoors
Field Repairs
Outdoors's Avatar
Originally Posted by High Center Hancho View Post
not always
Which part do you disagree with?
Old February 22nd, 2013, 09:06 PM   #13
Christmas Cookie
the idle part...vapor lock can cause a whole host of problems...some on the high end some on the low end...when I had my issues with vapor lock I couldn't even to get mine to fire, until the motor cooled off
Old February 22nd, 2013, 09:20 PM   #14
Toyfish
Toyfish's Avatar
Yes vapor lock affect all rpms not just the high end i dont think he is dealing with a fuel issue here at all
Old February 23rd, 2013, 11:44 AM   #15
Jeeper52
Budget, what budget?
Jeeper52's Avatar
I just put a 350 with a new fuel pump(mechanical) and the first start was a bi$#@ch to get started . I had to pressureize the tank to get gas to the FP and then to get through it and again to get throught the universal filter, after that I ran fine.The same motor in my 86 P/U would always give me greif if it sat for a while. vapour lock can happen when cool tooif the pump creates a vacuum and the fluid (gas) wont lift to start flowing but usually happens hot though. a heat sheild along the gas line will help
Old February 23rd, 2013, 12:15 PM   #16
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
Same here...
concreteguy82 is offline   Reply With Quote
Old February 23rd, 2013, 06:52 PM   #17
hotstuff
VAPOR LOCK Loss of power , stall or surge on acceleration after short engine off period in high temp.s. Major Causes = fuel volatility [vapor pressure ] a warm day in winter . Clogged fuel - inlet filter or screen . Low fuel pump pressure . And a whole bunch of other stuff
Old February 24th, 2013, 08:12 AM   #18
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
since i put the 318 in the xj i have had bad vapor lock runs like a champ till it gets hot. then it misses like hell and only way to keep it running it to keep rpms up but still misses when doing that, if i let off it dies and wont restart. going to wrap fule likes and put loves in hood to try to help with heat
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old February 24th, 2013, 08:17 AM   #19
92FleXj
stacks stacked on stacks
92FleXj's Avatar
I had a problem kinda like this on e with my Xj. It was the return line at the tank was pinched not keying fuel return. It would sit in the rail and boil. Once I got it to return it works great.
Old February 24th, 2013, 10:27 AM   #20
chevotass
chevotass's Avatar
ive ruled out vapor lock i think. back to fuel delivery, return or drive by wire throttle issues
Page generated in 0.37990 seconds with 83 queries
