TJ: cutting rear upper coil buckets off - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2013, 07:35 PM   #1
2fst4you
2fst4you's Avatar
Default cutting rear upper coil buckets off
What did everyone use to cut the welds on the inside of the frame?
Was removing the tub necessary?
Old February 19th, 2013, 07:56 PM   #2
joescamaro67
joescamaro67's Avatar
Nope. I used and will always use a gas hatchet.
joescamaro67 is offline   Reply With Quote
Old February 19th, 2013, 07:57 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I think I just used a cut off wheel on mine
H.o.r.e
Old February 19th, 2013, 08:11 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Torch, just don't be a retard and cut the frame.
Old February 19th, 2013, 09:00 PM   #5
2fst4you
2fst4you's Avatar
Dont think I can get the cut off in there did you have to move the brake lines before using the torch?
Old February 19th, 2013, 09:06 PM   #6
Common sense applies.............
Old February 19th, 2013, 09:29 PM   #7
2fst4you
2fst4you's Avatar
Sounds like thats a no I just need to be careful. I plan on reusing them just wanted to know the best way
Old February 21st, 2013, 09:45 PM   #8
2fst4you
2fst4you's Avatar
Cutting it off is easy when you don't need to reuse them. I couldn't cut just the weld because it was too hard to get to up top so I just cut the coil bucket bracket that made it easy
Page generated in 0.14668 seconds with 47 queries
