What are these called, and where to buy the cheapest? (Winch QD's) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2013, 09:46 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default What are these called, and where to buy the cheapest? (Winch QD's)
Looking for those in a 2 gauge. I don't think 4 is enough on a 8k winch?
What are they called so I don't have to pay Warns prices...
Old February 17th, 2013, 09:49 PM   #2
firehawk
Live Action!
firehawk's Avatar
I got some from Grainger.
Old February 17th, 2013, 09:55 PM   #3
Gorelord
Lost Soul
Gorelord's Avatar
The name Anderson power pole comes to mind.
......Never leave your cave without your club......
Gorelord is offline   Reply With Quote
Old February 17th, 2013, 09:56 PM   #4
mtx410
Send a message via AIM to mtx410
yeah, anderson connectors
mtx410 is offline   Reply With Quote
Old February 18th, 2013, 06:21 AM   #5
shawn
Resident HVAC/R Jambi
shawn's Avatar
I see those on fork truck battery chargers all the time. I bet they are in grainger or at any real electrical supply place.
Old February 18th, 2013, 09:02 AM   #6
bdd1469
bdd
bdd1469's Avatar
You can buy them at napa, probobly any autoparts store in the snowplow stuff.
I personally wont use them on a winch because it only takes a bad connection a few seconds to create enough heat to ruin your winch motor. Ask me how I know.
Old February 18th, 2013, 05:44 PM   #7
jeepfreak81
81 inches of fun
Its for a receiver mounted winch, so it has to have a connector of some sort. I want to be able to move it between the rear of the cj and yj.
I will see what price Napa has, they were pricey at Grainger, if I buy them there I might as well buy the kit.
Thanks guys!
Sent from my Nexus 7 using Tapatalk 2
Old February 18th, 2013, 07:21 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i bought mine from napa. i got the 175 amp ones. i can get the part number as i still have the package somewhere.
Old February 18th, 2013, 07:32 PM   #9
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
use semi truck plug that we us for traps motors on gravel trains. its 2 prong.
4x4xdodgeman is offline   Reply With Quote
Old February 19th, 2013, 04:18 AM   #10
bdd1469
bdd
bdd1469's Avatar
My warn 8274 will pull 400+ amps on a hard pull.
Old February 20th, 2013, 11:24 AM   #11
mtx410
http://www.mcmaster.com/#battery-connectors/=lk96ao
Old February 20th, 2013, 11:35 AM   #12
GearDrive
A little slow
GearDrive's Avatar
http://www.fastenal.com/web/search/p...emblies%22%7C~
Maybe use welding cable quick connects
GearDrive is offline   Reply With Quote
Old February 20th, 2013, 12:06 PM   #13
Lousypirate
Whoop Whoop
Lousypirate's Avatar
This. The other quick connects are not rated for that amperage. Bdd is correct on the quick heat from the ones rated for charging batteries. Keep em lubricated, at least put the female ones on the winch do you can keep mud /water out of the connectors.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old February 20th, 2013, 12:32 PM   #14
GearDrive
A little slow
GearDrive's Avatar
I would put a female on the pos and male on the neg on the truck and the opposite on the winch. That way you can't mix em up.
Old February 20th, 2013, 12:54 PM   #15
Lousypirate
Whoop Whoop
That would work too. I think you can get different colors to remedy that as well.
Old February 20th, 2013, 01:14 PM   #16
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
How are the connectors rated that you say aren't big enough? Continuous or peak? If it's peak, what's the rating for time? On the McMaster one I see it has an amp rating.. it doesn't go into any detail.
I dunno if you looked at the Warn site, but he's basically looking for the same part they sell, but not in the Warn package. I've seen the Warn parts in person, and they aren't any different than what others have posted. Going with the equivalent of what Warn sells seems to be reasonable to me; as I would expect they aren't going to sell something that turns to dust the first time you use it on a hard pull.
As for peak amp draw on an 8274.. have you checked the peak amperage to what the factory wiring is? I'm pretty sure they use 2-gauge on 8274 if that helps you find the answer...
JohnnyJ is online now   Reply With Quote
Old February 20th, 2013, 01:16 PM   #17
Wehan
Wehan's Avatar
Had a warn set. They got water in them and froze, split all to hell and could have burnt down my jeep if I hadnt cought it.
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Old February 20th, 2013, 01:24 PM   #18
Timglide
It's Me
Timglide's Avatar
Try snow plow cables, two prong plug with large gauge copper.
Timglide is offline   Reply With Quote
Old February 20th, 2013, 02:45 PM   #19
Lousypirate
Whoop Whoop
I did just look at them on McMaster, they make ones rated up to 350A, assuming peak.
The quality of the connection is what worries me. I feel that welding cables have a much better connection than these plugs...
Do whatever you want, it's your rig.
I'd rather be safe than sorry.
Old February 20th, 2013, 03:31 PM   #20
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
That was my point. It's all an assumption.
As far as safety, I've seen a set of those cables on most every wrecker, and I'm sure they get plenty of connect/disconnect cycles. Proper care goes a long way.
Page generated in 0.44619 seconds with 83 queries
