2006 Dodge Ram - front calipers won't engage? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2013, 12:55 PM   #1
jeeperstrudie
AdvoCare Distributor
jeeperstrudie's Avatar
Send a message via Yahoo to jeeperstrudie
Default 2006 Dodge Ram - front calipers won't engage?
Ok guys need some help...I can't figure out what the heck is going on.
changed the front pads on my 2006 dodge ram, done them 100 times without any problems. The calipers will not engage, all i have rite now is back brakes (not very safe for driving)
I went and took them back apart to see what if anything was keeping them from engaging and can't seem to find any problems.
Anyone have this experience before?
Truck is 2006 dodge Ram quad cab, 4.7 liter v8, 215,000
Also, there is brake fluid to the required level and the brake lines have not been touched so I don't think bleeding will do anything.
jeeperstrudie is offline   Reply With Quote
Old February 18th, 2013, 01:01 PM   #2
jeeperstrudie
I can't believe I'm the only one out there that has had this issue....Any ideas from anyone?
Old February 19th, 2013, 07:48 AM   #3
barry1me
Just another day
barry1me's Avatar
Does your pedal have the same feel as it did before? Did you try to bleed the front brakes? Any codes your throwing?
barry1me is offline   Reply With Quote
Old February 19th, 2013, 08:55 AM   #4
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Crack the bleed screw and press the brake pedal. See if you're squirting fluid. If you are, you know your master cylinder and lines are good. If your pistons aren't moving, perhaps when you pushed them back into the caliper they are now seized or cocked sideways in there. If you have a high enough pressure air compressor, you can remove the bleeder screw and blow air in there to hopefully push the pistons out. Put a piece of wood or something else in the caliper to catch the pistons so you don't shoot them all the way out of the caliper.
If you aren't getting fluid out of the caliper, you could have some crud or something else blocking the lines from pushing fluid back up. Keep moving up the lines to check if you are getting any fluid pressure when hitting the brake pedal. You may just need a brake fluid flush.
Old February 19th, 2013, 09:18 AM   #5
jeeperstrudie
Awesome guys, I'm gonna check to see if I'm getting fluid tonight, I never bothered trying that because I never cracked the system open.
Sent from my EVO using Tapatalk 2
Old February 22nd, 2013, 02:02 PM   #6
GreaseMonkey
Pew pew!
So what happened?
Old March 30th, 2013, 10:06 PM   #7
jeeperstrudie
Ok, so I had the wife get in the truck pump the brakes and hold them down, I get a dribble of fluid out the bleeder no squirt, just a dribble....Bad master cylinder? thoughts?
Old March 30th, 2013, 10:08 PM   #8
rammanriley
rammanriley's Avatar
Did you twist the flex hoses when you put the calipers back on?
rammanriley is offline   Reply With Quote
Old March 30th, 2013, 10:12 PM   #9
jeeperstrudie
nope...double, triple checked that today....
Old March 31st, 2013, 10:39 AM   #10
GreaseMonkey
Pew pew!
Crack a bleeder screw at the master and see if it squirts. Then you know if it's a bad master cylinder or you have a restriction in between the caliper and master.
Old March 31st, 2013, 10:48 AM   #11
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Try cracking the line at the caliper and see if you get more than a dribble. If you don't get more than a dribble crack the line at the master cylinder and check again. If you get good pressure I would bet the hoses to the calipers are bad. If not you probably have a master cylinder problem.
GNJEEPN is offline   Reply With Quote
Old March 31st, 2013, 02:15 PM   #12
jeeperstrudie
got a little fluid when I cracked the front connection to the caliper (closest to the front of the truck) when i cracked the rear connection to the caliper I go nothing (closest to the cab of the truck)
So, my guess is the master cylinder, can someone please agree with me or give me better guidance...(sorry, I'm so pathetic, but i'm slowly losing my confidence with this) UGH!
Old March 31st, 2013, 08:21 PM   #13
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
If you had someone putting pressure on the brake peddle while you did this and there was brake fluid in the master cylinder. I would say you have a problem with the master cylinder. Might try bleeding the master cylinder first to see if it will pressurize. If it wont it probably needs a rebuild or replacement.
Old May 1st, 2013, 02:24 PM   #14
jeeperstrudie
turned out to be the master cylinder was bad. swapped it out bled the brakes and TADA...I can stop! I love it when I can stop!!!
Old May 1st, 2013, 02:35 PM   #15
GreaseMonkey
Pew pew!
Page generated in 0.30839 seconds with 68 queries
