Any interest in LS Swap brackets for 88-98 trucks? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 15th, 2013, 04:52 PM   #1
beertestr
Default Any interest in LS Swap brackets for 88-98 trucks?
Hey guys. I did an LS Swap on my 1994 Z71 Silverado back in 2010, and drove it as a DD for almost two years before I sold it. I fabbed up my own motor mount brackets to fit the motor so that it mated up to the existing trans without relocating any of the driveline. I transferred my designs to CAD and I'm just starting to make them for others.
These are direct bolt on brackets, made out of 1/4" steel, you do not use the stock SBC clamshells at all.
No trans relocation required, so you can retain all your existing driveshafts. You even run the stock truck oilpan. Stock truck exhaust manifolds clear the frame and if you can snag it with the motor, the stock LS y-pipe clears the frame trans and transfer case. In fact, I used a complete 2004 exhaust system, I just made up frame side hangers to adapt the entire exhaust.
The brackets let you run all the LS Truck accessories and centers the mechanical cooling fan in the stock V8 fan shroud. On the 4WD
I am also working on an AC compressor bracket that lets you reuse the R4 style compressor on the 88-95 trucks. You should even be able to reuse your stock AC lines.
Anybody interested?
Here's some pics of a set I just shipped out. The slots are there to allow a little adjustability fore aft in one of the other applications these work with.
While I used them on my 88-99 body style trucks, they should also work with 73-87 v8 trucks as well.
Sitting like they would on the side of the block.
This is my 94 with a 4.8L in it.
Sent from my DROID BIONIC using Tapatalk 2
beertestr is offline   Reply With Quote
Old February 22nd, 2013, 11:17 PM   #2
beertestr
Bump, pics added.
Old February 28th, 2013, 06:16 PM   #3
beertestr
3 sets sold, anybody else?
Old July 13th, 2013, 07:18 AM   #4
dudekcj7
rev limiter racing
dudekcj7's Avatar
What kind of price you talking?
dudekcj7 is offline   Reply With Quote
Old July 13th, 2013, 08:45 AM   #5
montecarlo33
The Violator
montecarlo33's Avatar
There is a difference in the 2wd mount and the 4wd Mount, looks like your just making the 4wd one, but it does look good. My dirty dingo ones also had some adjustability in the mounts, may be something to think about.
Old July 13th, 2013, 09:05 AM   #6
beertestr
$90 shipped. PM me if interested
Old July 13th, 2013, 09:10 AM   #7
beertestr
Actually while the frames are different the clamshells on the engine are fhe same. My brackets work on a 2wd and 4wd. I had these brackets on a 93 Sierra 2wd before I built my 94 z71.
The mounts allow 3/8" adjustability fore aft, but on the 88-98 trucks you really don't need it. On a 4wd, I recommend you run stock location to keep from having to mod your tcase mounting and driveshafts.
Old February 16th, 2015, 05:29 AM   #8
beertestr
Bumping this back up. I've had a few guys on the forum ask about these. Stronger and cheaper than the others, true bolt in design.
Page generated in 0.49547 seconds with 47 queries
