ford 205 gm4l80e - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2013, 07:19 PM   #1
Windsorf350
Rusty Racing
Windsorf350's Avatar
Default ford 205 gm4l80e
what does it take to put a ford np205 behind a gm 4l80e 4x4 transmission? thanks
Windsorf350 is offline   Reply With Quote
Old February 13th, 2013, 07:35 PM   #2
Bleay
sick of jackstand wheelin
Bleay's Avatar
Swap the input on the tcase to a 32 spline.
http://www.northwestfab.com/Transfer...afts_c_74.html
Bleay is offline   Reply With Quote
Old February 13th, 2013, 07:39 PM   #3
Windsorf350
Rusty Racing
which one is needed? I don't see one that is ford 32 spline, or do you use a gm 32 spline input shaft?
Old February 16th, 2013, 05:01 AM   #4
littletrucker
I'd hit that
littletrucker's Avatar
You use the chevy 32 spline input and put it in the ford case.
Old February 16th, 2013, 10:29 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you will also need an adapter to mate the 2 cases together. the bolt pattern is different from the ford to the chevy and is clocked differently. I am running into the same issue trying to mate a ford 205 to a NV4500 manual. same exact tailhousing and output shaft as the 4l80. If you have access to a milling machine you could cut a spacer/adapter from aluminum to bolt the 2 cases together then run a long style 32 spline input in the 205. thats kinda what my plan is anyways.
Page generated in 0.16765 seconds with 38 queries
