Kicker 1200.1, L7 15" in custom box custom fit for XJ read on $500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2013, 12:44 PM   #1
PaulB84
Default Kicker 1200.1, L7 15" in custom box custom fit for XJ read on $500
Pics coming soon
Kicker KX1200.1 1200 watt mono channel 4, 2 or 1 ohm stable, designed as a match for the L7
Kicker L7 15" in custom ported box-fits between XJ wheel wells (I'm sure it fits other models as well but that's what I had it built for)
I also have a custom false bottom floorplate for Jeep XJ that houses everything listed (except sub of course) under it, keeping your entire cargo area free and electronics out of sight and protected. Very clean install, quick disconnect sub speaker wire terminals, pull sub box out, have entire cargo area.
If you have an XJ, this system will drop in with zero fuss. Of course it would work in any ride, I can even help with the install if you're not mobile AV savy
This system has some serious power. Sub and amp are both 1 ohm stable. Wanted to keep it around for my next XJ project but times are tough, gotta move it.
$500
313-410-8894
PaulB84 is offline   Reply With Quote
Page generated in 0.20138 seconds with 26 queries
