Need help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2013, 01:07 AM   #1
xNMTBx
xNMTBx's Avatar
Default Need help!
I just bought a 98 Chevy Blazer with a 4.3. The guy glued the coil back on after stripping the bolts and broke it off. The truck starts up perfect but as soon as I start giving it gas it spits and sputters. Need this issue fixed soon... Thanks
xNMTBx is offline   Reply With Quote
Old February 13th, 2013, 08:29 AM   #2
firehawk
Live Action!
firehawk's Avatar
Have you checked the fuel pressure yet?
Old February 13th, 2013, 10:30 AM   #3
xNMTBx
xNMTBx's Avatar
Not yet but will do that today.. It sat since November...
Old February 13th, 2013, 10:37 AM   #4
Toyfish
Toyfish's Avatar
Cap and rotor
Old February 13th, 2013, 11:16 PM   #5
Windsorf350
Rusty Racing
Windsorf350's Avatar
I would replace the said "broken coil", check the fuel pressure, if the pressure is good I'd check the cap and rotor (replace if needed). If that doesn't solve it I would check plugs and wires. If you still have this problem there is probably a more serious electrical issue, or bad sensor somewhere.
Windsorf350 is offline   Reply With Quote
Old February 14th, 2013, 09:04 AM   #6
bdd1469
bdd
bdd1469's Avatar
^^ fuel pressure first, cap and rotor second, fresh gas also
Old February 15th, 2013, 02:59 PM   #7
xNMTBx
xNMTBx's Avatar
What should the fuel pressure be at?
Old February 16th, 2013, 06:59 AM   #8
Toyfish
Toyfish's Avatar
45-55 and those r also known for the distributors to go bad
Old February 16th, 2013, 03:56 PM   #9
xNMTBx
xNMTBx's Avatar
Ok thanks
Old March 12th, 2013, 12:11 PM   #10
xNMTBx
xNMTBx's Avatar
So the lower intake is good, replaced the plenum gasket and I-rings, had a major vacuum leak, and is still doing it... Going to try and find a texting valve and check the fuel pressure on it
Page generated in 0.47125 seconds with 53 queries
