YJ: Skid Plate Drop Removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2013, 10:14 PM   #1
Prox445
Default Skid Plate Drop Removal
I am looking to move my skid plate back up. I have a 4" lift. Do I need to do a MML or longer shaft. I don't drive it on the roads. I just want to know if I run the risk of the shaft breaking or slipping out with articulation.
Prox445 is offline   Reply With Quote
Old February 13th, 2013, 12:16 PM   #2
Toyfish
Toyfish's Avatar
I would say yes on the mml
Old February 14th, 2013, 11:50 AM   #3
Ashland82391
Ashland82391's Avatar
a mml would help a little but you wont be able to get rid of the tc drop. Even if you had 10 degree axle shims in the back you will still have major vibes that will result in ujoint failure, pinion and tc out put seal failure, and even possibly damage to your t case . you have to do the sye to get it back to stock.
Ashland82391 is offline   Reply With Quote
Old February 14th, 2013, 11:53 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
if its a trail rig you will be fine . i ran my dd like that with no problem for two years
H.o.r.e
Old February 14th, 2013, 05:47 PM   #5
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
If you have a 4 inch lift and you have a slip yoke T-case and your rear pinion is not rotated from stock position AND you put the T-case back up where it used to be then you risk both breaking a shaft, and having it slip/fall out.
A mml will not be enough, you need a SYE (slip yoke eliminator) and then I imagine some shims on that rear axle. MML are good when you just need about 1-2 inches of lift compensation and just a very slight angle change.
jeeps are short wheelbase and your leaf springs have axle wrap...if you do go with a longer shaft bad things will happen besides your shaft falling out, if your shaft falls out bad things happen.
Even if it's just a trail rig do you really want to gain that underside clearance and deal with a donkey ass-suck trail repair with tow, or just keep it there til you can do it right.???
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old February 14th, 2013, 05:58 PM   #6
Toyfish
Toyfish's Avatar
Im currently running my tj with a 4" lift and no tcase drop or sye just a mml
Old February 15th, 2013, 10:18 PM   #7
toolmantim
toolmantim's Avatar
4" suspension lift?? What size MML?
Old February 15th, 2013, 10:22 PM   #8
Toyfish
Toyfish's Avatar
Yup 4" suspension lift 1.25" body lift and 1" mml it has some driveshaft vibes but i dd it
Old March 2nd, 2013, 11:01 PM   #9
Prox445
Bought a Brown Dog MML. This is a great product with great customer service!!!!
I don't drive on the road so I don't know about vibs but I didn't have any issue. I had this thing flexed to the max and didn't drop the driveshaft. I'm glad I did it!!!
Page generated in 0.32142 seconds with 50 queries
