What Year and Model Jeeps Came With a HP30 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2013, 11:08 PM   #1
Prox445
Default What Year and Model Jeeps Came With a HP30
I am kind of confused. I have a '94 YJ. I have a HP30. My buddy says it can't be. I know it is because I can see it. Whats the deal. Is mine factory or did the previous owner put it in. He says only Cherokees came with HP30's
Prox445 is offline   Reply With Quote
Old February 13th, 2013, 06:05 AM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Yours has a hp from the factory but it isn't as desirable because of the vacuum disconnect.
Old February 13th, 2013, 06:43 AM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Yours is. Just throw a tj axle shaft in it if you're worried about the disconnect. I think that Cherokees before 99 had them too.
Old February 13th, 2013, 07:33 AM   #4
GREASYHANDS
GREASYHANDS's Avatar
Get smarter freinds
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 13th, 2013, 07:34 AM   #5
curbdog17
Mini Van
curbdog17's Avatar
Originally Posted by GREASYHANDS View Post
Get smarter freinds
curbdog17 is online now   Reply With Quote
Old February 13th, 2013, 11:21 AM   #6
Prox445
Get smarter freinds
Old February 13th, 2013, 11:22 AM   #7
Prox445
Ok, thanks for the help. I plan on doing a tj/xj shaft swap. From what I understand all I need to do is get the correct seal and toss them in?
Old February 13th, 2013, 01:23 PM   #8
GREASYHANDS
Correct.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 13th, 2013, 04:20 PM   #9
chadcooper55
If I'm not mistaken aren't the tj shafts from an abs axle stronger than non abs? I may be wrong.
Old February 13th, 2013, 04:35 PM   #10
robbietap
Nope.
robbietap is offline   Reply With Quote
Old February 13th, 2013, 04:46 PM   #11
chadcooper55
After a little research you are correct, they are the same. For some reason I was thinking they had a little bigger joint.
Old February 13th, 2013, 11:16 PM   #12
xNMTBx
xNMTBx's Avatar
My 89 Cherokee had a HP30
xNMTBx is offline   Reply With Quote
Old February 13th, 2013, 11:40 PM   #13
kkodet
kkodet's Avatar
Didn't they up the U-joint size around 95 though?
Old February 14th, 2013, 08:45 AM   #14
Yeah, around that timeframe. I think starting with ABS equipped models. Before that, they were 5-260x, after, they were 5-297x
Old February 14th, 2013, 08:54 AM   #15
Wehan
Wehan's Avatar
Perfect time to do a lunchbox locker as you will be 90% of the way in because you need to pull the carrier to do the seals anyway.
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Page generated in 0.25447 seconds with 68 queries
