Zr2 sfa swap?? Need in depth advice - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2013, 02:17 PM   #21
1TFROT
1TFROT's Avatar
Originally Posted by wadey View Post
An easier front output to find is a 231J, just swap out the outputs and use a 231J front output seal on your case. That way you can run jeep cv shafts. I also ran with the stock rear ds for a long time.
good call. I did it the way I did to get the HD chain
1TFROT is offline   Reply With Quote
Old February 10th, 2013, 02:26 PM   #22
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Well you can swap the 231j yoke on to a 231c hd output and have the best of both worlds. However you may end up like me and have 3 different partial t cases laying around and one bastardized case in the truck
Old February 10th, 2013, 02:29 PM   #23
bighroder
bighroder's Avatar
I've seen flat top d 44s not so much servive but exist under cummins swapped rigs I know itll hold the weight I could get a cheap d 60 but I don't see why, I'd need its gunna be a conservative build 33's at max I'll join the site when I go to start the build
bighroder is offline   Reply With Quote
Old February 11th, 2013, 12:31 AM   #24
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
huh?
Old February 11th, 2013, 09:10 PM   #25
JACK48461
HEAVY D
I Know i'm going to catch hell for this but i ran a D30 high pinion on my zr2 in this thread i built. http://www.greatlakes4x4.com/showthr...CK48461&page=3 i did do the yoke swap the Wadey recomended worked out beautiful. I drove mine for show boating around town though and mild wheeling. The guy that currently has the truck since I sold it put a mildly built 5.3l in it new custom front driveshaft and harden front shafts and he goes to the dunes alot. (not mud) Mild trail riding and hasnt broke anything. But between buying the axle used all new brakes. Using my stock hub bearings on that axle and having spacers made outta 1/4" plate to keep my offset right for the brakes and redrilling the lug pattern in the xj rotors i had less than $600 in it. Thats counting a used set of 3.73 gears to match my rear. I did leave it open up front though.
JACK48461 is offline   Reply With Quote
Old February 11th, 2013, 09:13 PM   #26
JACK48461
HEAVY D
Just check out the build and pics for ideas you may be able to coil spring pretty reasonable. Idk how heavy yours will be or anything or what your plans are just showing you an option. But if you plan to wheel hard the old saying will always hold true go big or go home. Just throwing this out incase your just going for something different to tool around with as a DD
Old March 12th, 2013, 11:28 PM   #27
bighroder
bighroder's Avatar
I'm in between doing theaxle swap first or doing the engine swap the truckhas 200k on its always Beenmmaintained tho the motor is gettin tired I found an hp d44 and Dana70 with 3.55 gears but I am unsure if the 4.3 will run with those low gears ? +31's
Old May 15th, 2013, 01:16 AM   #28
crazygrady127
crazygrady127's Avatar
Originally Posted by silveradoboy View Post
Wade beats on his rig more than anyone I know!
Hey Justin do you have any straight body panels left??
I will second that Sam , And I don't think there is any straight panels left on it now !! And Wadey is right if your going to build a D44 just go with tons !! I would have actually saved money if I would have done that !!
Tear It Up - Fix It - And Do It Again
crazygrady127 is offline   Reply With Quote
Page generated in 0.31515 seconds with 47 queries
