Ford 9 " disk swap wheel studs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 9th, 2013, 03:39 AM   #1
xj bmx
SLAYER!!
xj bmx's Avatar
Send a message via AIM to xj bmx Send a message via Skype™ to xj bmx
Default Ford 9 " disk swap wheel studs
So I have everything need to do the swap using RuffStuff brackets and such but the last part I need is the wheel studs.
It seems some guys just run a longer stud but that doesn't sit well with me since the rotors have a .641" hole and the studs are .495". That seems a bit unsafe during hard braking as I imagine it would shift some and over time could cause issues. Also the rotor has some up and down play on the axle flange so I imagine that would cause a bit of run out and an unbalanced rotor along with with wear issues and so forth. Now I could find studs with a longer knurled area but that's still .620".
Am I over thinking this or is this the norm? I was thinking of making some .072" thick sleeves to be able to just run a standard stud. But if there is a known studded that will work I'll just for with that.
xj bmx is offline   Reply With Quote
Old February 9th, 2013, 04:58 AM   #2
welderbrian
welderbrian's Avatar
I run the same stud that's on older dana 44 fronts
welderbrian is offline   Reply With Quote
Old February 9th, 2013, 08:28 AM   #3
Torg38
TorgFab
Torg38's Avatar
It is really common for aftermarket rotor to have larger holes, With ~.075 on both sides of the stud. Don't worry about it. They will be fine. Just make sure you torque the wheels.
Torg38 is offline   Reply With Quote
Old February 9th, 2013, 10:27 AM   #4
xj bmx
SLAYER!!
xj bmx's Avatar
How old? I have a '74 f150 44 front, the studs for that would be perfect if the rotor went behind the axle flange like it would in the front, since it has a .0639" shoulder at the bottom then the knurling it wouldent press in to the shaft.
Old February 9th, 2013, 10:31 AM   #5
xj bmx
SLAYER!!
xj bmx's Avatar
In that case maybe I'll just get a studs with a longer knurled area, that would take the gap down a bit more just to be on the safe side.
Page generated in 0.30599 seconds with 38 queries
