Local source for shock seals - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2013, 08:39 PM   #1
cerial
1200PSIg Double acting
cerial's Avatar
Default Local source for shock seals
I am looking for a source of 4" seals around Grand Rapids. Within a hour of 49333 would be fine also.
I am building a internal floating piston shock (not suspension) with a 4" ID. The 3 seals on the internal floating piston will need a "backup" scraper on the oil side, a main "multiple ribbed" seal, and a air scraper on the nitrogen side.
These seals will need to work within a range of -30 to 250 degrees F. The fluid is engine oil and the compression side is nitrogen.
I will need a total of 8 oil scraper seals, 8 "multiple ribbed"main seals, and 8 nitrogen seals. I am thinking poly for all but will gladly take advise. I will also buy extra's if they are in stock.
Once I have the seals I will build the floating piston to match them.
If need be I will order overseas. But, if at all possible I would prefer to buy this locally. So, if you guys know of any or are any yourself the information would be great.
Thanks for reading.
Old February 7th, 2013, 08:53 PM   #2
cerial
cerial's Avatar
Dang it I forgot to mention the material.
The material is steel.
Old February 7th, 2013, 10:06 PM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Are you from the grand rapids area?
Old February 7th, 2013, 10:07 PM   #4
XJcoupe
1ton XJ
XJcoupe's Avatar
are you going to double weld these
Old February 7th, 2013, 10:31 PM   #5
cerial
cerial's Avatar
Yes, Middleville is around 20-40 minutes South East of GR depending on what part.
Old February 7th, 2013, 10:33 PM   #6
cerial
cerial's Avatar
I have lived within a hour of GR most of my life.
Page generated in 0.16493 seconds with 40 queries
