Site bugged??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2013, 08:11 PM   #1
michigan_Redneck
semi-pro web crawler
michigan_Redneck's Avatar
Send a message via MSN to michigan_Redneck Send a message via Yahoo to michigan_Redneck
Default Site bugged???
Every page I load Avast blocks an unsafe site...
http/afe.specificclick.net/?l
I'll double check my pc, but is only happening here.
michigan_Redneck is offline   Reply With Quote
Old February 6th, 2013, 08:12 PM   #2
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
no problem here.. Choose better porn sites.
Old February 6th, 2013, 08:13 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
+1
Old February 6th, 2013, 08:55 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
http://www.superantispyware.com/
sounds like the creeping crud. try this and see if you scrape it off
Yetti
Old February 6th, 2013, 10:28 PM   #5
BlooMule
Old School
BlooMule's Avatar
-rw-rw-rw
Old February 6th, 2013, 10:30 PM   #6
jaysusr
jaysusr's Avatar
Avast=slow system operation.
Old February 8th, 2013, 09:18 AM   #7
michigan_Redneck
ok, it seems it was just thus pc, but hitman pro and avast boot time scans every fond anything.
did a full system clean with ccleaner seems to have gotten it.
thank the replies.
jaysusr - avast did have a big problem with their network driver causing slow boot times. however that was a couple of versions ago (and 2009-2010)
now days it one of the lightest on system resources, avg scan times, faster normal ops, top rated and ONLY FREE rated anti-virus apps out there.
Android seems a bit slow on older phone, but pc based is pretty darn good.
as of 2012 AVG or ad-aware will really slow you down.
Again, thanks for the input
Old February 8th, 2013, 10:01 AM   #8
chevykid389
chevykid389's Avatar
having the same problem now with avast
chevykid389 is offline   Reply With Quote
Old February 8th, 2013, 11:02 AM   #9
capone
capone's Avatar
I'm having a problem with avast too. But it only happens when I click on this site
capone is online now   Reply With Quote
Old February 8th, 2013, 11:43 AM   #10
scrambled82
scrambled82's Avatar
I've got it too but only on GL
Malicious URL blocked - Great Lakes 4x4. The largest offroad forum in the Midwest
scrambled82 is offline   Reply With Quote
Old February 8th, 2013, 01:14 PM   #11
michigan_Redneck
clear history then run ccleaner to clear EVERYTHING.
It's something hidden in the temp files.
If you use chrome, it might be saving it to the web profile.
Old February 8th, 2013, 03:39 PM   #12
capone
capone's Avatar
I'm using Google chrome. I'm computer illiterate what is the web profile and how do I fix it?
Thanks
Old February 8th, 2013, 05:13 PM   #13
michigan_Redneck
Anyone NOT running avast having this problem?
capone - let me double check that will fix it. do you have a google account that saves you bookmarks and PWs?
looks like it might some of the ads across the top. I have popup once on my desktop (avast Pro), but then hit several more posts with out it.
Old February 8th, 2013, 05:29 PM   #14
jeepinRRT
jeepinRRT's Avatar
Site works fine for me and I have no idea what an avast is.
jeepinRRT is offline   Reply With Quote
Old February 8th, 2013, 05:47 PM   #15
capone
capone's Avatar
Yes I do.
Old February 8th, 2013, 06:43 PM   #16
michigan_Redneck
ok, done some more research. this is a malware site. It sends viruses (kinda) to your pc via a tracking file called a cookie. It also looks like a problem with chrome allowing that cookie to be saved to the PC. (FYI Firefox does not seem to have this problem)(I haven't tested any other browsers) - still working on blocking it
Old February 8th, 2013, 06:45 PM   #17
michigan_Redneck
First print or copy and save this post.
then goto your homepage (any page other than here)
next click the 3 lines on the upper right corner (settings)
go down to settings, click
at the bottom click "Show Advanced Settings...
under "Privacy" click the button "Content Settings..."
add a check to "Block third-party cookies and site data"
next click the button "Manage Exceptions.."
in the box "Add a new hostname" type (or copy and paste) - afe.specificclick.net
next to that select "BLOCK" and click "OK" and "OK" again
restart your browser
you MIGHT want to scan your PC with your favorite anti virus/antispyware
then clean it with a system cleaner (Ccleaner,Wise care 365, or winutilities)
PS.
IF you need help with this, I am PC tech of nearly 20 yrs. I run my own business and can remote into your pc to do these steps for you or can walk you through it over the phone.
email and phone are in my website , or PM contact info for you.
Page generated in 0.35506 seconds with 74 queries
