locker issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2013, 06:49 PM   #1
Blakemore00XJ
Blakemore00XJ's Avatar
Default locker issue
hello just seeing if anyone had a rough idea of what i have going on..just had gears done in my wrangler dana30 front, 44 rear, went from 373s to 456. didnt have to change carriers just the ring and pinion. every seems good until i put the jeep in 4 wheel drive and when it is the lock right locker wont disengage at all.. wether im in the gas or not. so its pushing all over the road binding up like i have a welded front end. the only way it unlocks is if i put it in 2wheel drive put it in reverse tap the gas and then its fine back in 2wheel unlocked. anyone have an idea? thanks for the help
Blakemore00XJ is offline   Reply With Quote
Old February 6th, 2013, 07:04 PM   #2
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Maybe they messed up the locker install?
Mulely is offline   Reply With Quote
Old February 6th, 2013, 07:11 PM   #3
KCameron13
Weekend Warrior
KCameron13's Avatar
This is what it sounds like to me. Maybe an issue with a spacer during the install. Did a shop install? If so, take it back and have them double check to be sure.
KCameron13 is offline   Reply With Quote
Old February 6th, 2013, 07:13 PM   #4
Blakemore00XJ
locker was in it before the gears where installed and it worked fine. he didnt have to change the carrier just the ring and pinion. so i dont think the locker was messed with.
Old February 6th, 2013, 07:17 PM   #5
Blakemore00XJ
if back lashing isnt done correctly could it cause the locker to think its under load and lock up? i had someone do it off here, i took it back today and still couldnt get it right.
Old February 6th, 2013, 07:50 PM   #6
Sandals
Fucking Zen as Shit
Sandals's Avatar
they would have had to remove and re-install the locker though, maybe the different size of gear is causing the locker to bind somewhere? of like also said maybe a missed spring or shim put in wrong.
Sandals is online now   Reply With Quote
Old February 6th, 2013, 08:08 PM   #7
Blakemore00XJ
the locker was never taken apart or pulled out of the carrier.. from what i was watching he just had to change the ring gear and pinion gear along with the new bearings and stuff that come with the kit.
Old February 6th, 2013, 08:15 PM   #8
Lousypirate
Whoop Whoop
Lousypirate's Avatar
not to sound like a broken record, but it does sound like backlash.
did they happen to re-use the crush sleeve? Did they check the backlash/tooth engagement/shim depth behind any new bearings?
Lousypirate is online now   Reply With Quote
Old February 6th, 2013, 08:40 PM   #9
Mulely
Mulely's Avatar
The backlash would make sense. Pop your diff cover and throw an indicator on it and just check. Might end up saving your gear set.
Old February 7th, 2013, 07:29 PM   #10
Muttly
Muttly's Avatar
Please explain how they changed the pinion or ring gear without removing the carrier and/or locker ????
Muttly is offline   Reply With Quote
Old February 7th, 2013, 07:41 PM   #11
Wehan
Wehan's Avatar
Dana 30 uses 2 diferent size carriers. He is saying he kept the carrier he had when he took it in and seeing as its a lunchbox locker the shop didnt have to touch it to do the gear swap.
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Old February 7th, 2013, 07:47 PM   #12
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Dana 30 is a FF. Just need to pull the shafts out, unbolt the carrier straps, and the carrier falls right out. All you have to do is swap ring gears.
Old February 7th, 2013, 08:11 PM   #13
Lousypirate
Whoop Whoop
I have to doubt that they neglected to swap the pinion, as your comment implies.
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old February 7th, 2013, 08:22 PM   #14
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
My comment implies that you don't need to pull the locker to change a ring gear (in OPs case) in a D30 unless you are changing carriers.
Old February 7th, 2013, 08:41 PM   #15
Lousypirate
Whoop Whoop
True statement.
Mary Jane (46 CJ2a)
Old February 8th, 2013, 04:02 PM   #16
Dylan
Dylan's Avatar
You, I will smack for this comment
Check your tire pressures both left and right and front and rear.
Old February 8th, 2013, 05:37 PM   #17
Wehan
Wehan's Avatar
Do the gears match? Both front and rear are 4.56 or whatever you had put in? Jack it up and double check by turning driveshaft and counting rotations.
Old February 16th, 2013, 11:35 AM   #18
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
did you take your old ring and pinion back or did the person keep them?
4x4xdodgeman is offline   Reply With Quote
Old March 14th, 2013, 07:03 PM   #19
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Did you ever figure this out?
What size tires?
It's not backlash.
Old March 15th, 2013, 07:48 AM   #20
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
My first thought.
Page generated in 0.44178 seconds with 83 queries
