T-Case chain rattle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2013, 07:11 AM   #1
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Default T-Case chain rattle
I'm driving to work this morning and I was coming up to a red light. As I'm slowing down, I noticed a sound. It sounds like a click, almost like a lunch box locker when it clicks. I listen closely and it sounds like it's coming from my tcase. Any idea what this might be? It has never done this before
Old February 6th, 2013, 07:11 AM   #2
dfm_13
dfm_13's Avatar
Mine did that. It ended up being the output shaft bearing.
dfm_13 is offline   Reply With Quote
Old February 6th, 2013, 08:45 AM   #3
bdd1469
bdd
bdd1469's Avatar
If your chain gets stretched out bad enough it can rub on the case. If you drain your fluid and it looks like aluminum you have found your problem.
You can put a hd chain in it from alloy usa or put the fat chain in it from a 241 if you get the some other parts with it. Very few parts inside to wear out and easy to rebuild.
I would pull the drive shafts first and check the ujoints and centering ball.
Page generated in 0.22641 seconds with 32 queries
