89 tracker, worth $200 with bad engine? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 5th, 2013, 02:19 PM   #1
Wehan
Wehan's Avatar
Default 89 tracker, worth $200 with bad engine?
Guy at work has an 89 tracker auto
He drove it home last night and the oil light came on so he toped it off but when he got home it was knocking. He is asking $300 obo I'm thinking of offering $200.
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Old February 5th, 2013, 02:23 PM   #2
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
If you don't want it.....i'll take it!
hawkscj5 is offline   Reply With Quote
Old February 5th, 2013, 02:25 PM   #3
Complete Off Road
Complete Off Road's Avatar
'90 and older trackers have a slightly different t-case design that doesn't allow putting in the 4.24 t-case gears.
I think there are a few parts on there some Samurai guys might want...the front carrier for one...
I guess the 'is it worth $' depends on what you might possibly do with it.
Complete Off Road is offline   Reply With Quote
Old February 5th, 2013, 03:10 PM   #4
jerm97xj
I fixed it!!!
jerm97xj's Avatar
Buy it for $200, install a $200 motor, install a cheap set of used 31" mud tires for less than $200 and enjoy way more than $600 worth of fun for the next few years. A friend of mine had a $400 tracker in HS and we had a blast with it. It would go about anywhere.
jerm97xj is offline   Reply With Quote
Old February 5th, 2013, 04:32 PM   #5
Wehan
Wehan's Avatar
Im thinking replace engine and 31's. Do I need to lift it or trim fenders to fit 31s?
Old February 5th, 2013, 04:47 PM   #6
Complete Off Road
I would guess that trimming would be required. The stock tracker tires are about 29" iirc.
One of my wheelers is a tracker, I took it out for one run with the stock ifs front and just cut and trimmmed to fit 36" tsl's. That was a fun day.
Old February 6th, 2013, 11:59 PM   #7
scottie
Eye candy
scottie's Avatar
If its not rusty it probably is, but as stated 89 is kind of a bastard year.
For sure you can part out the major parts (Fuel Injection, Axles/carrier) and scrap the rest and make money.
If it's not too rusty, probably not a bad deal.
Old February 11th, 2013, 01:41 PM   #8
Wehan
Wehan's Avatar
Update. Its a manual and im going to look at it this weekend. It will most likely follow me home. :D
Old February 11th, 2013, 06:56 PM   #9
Wehan
Wehan's Avatar
Where is the best place to find an engine? Local yards want between 450-600 for 150k engines
Old February 11th, 2013, 08:15 PM   #10
scottie
Eye candy
scottie's Avatar
zuwharrie.com, or depending on what is wrong with it just rebuild it yourself.
Old February 11th, 2013, 09:34 PM   #11
Wehan
Wehan's Avatar
Fucker scrapped it...
Page generated in 0.25318 seconds with 57 queries
