14 ff pinion angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 5th, 2013, 12:00 PM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default 14 ff pinion angle
What is the max pinion angle you guys would run . Im moking mine up and I kept the T/c as high as poss. and have my pinion pointed up to the tc. It sits at 28* I think that is too high, but by how much. I need to lower the tc as well( the output flange is at 90* to the ground.. I tryed hard to keep the tc as high as possible through the whole build.Crap!!.
Old February 5th, 2013, 12:42 PM   #2
littletrucker
I'd hit that
littletrucker's Avatar
I would worry less about the axle and more about the angle your driveshaft needs to run at.
If you have a cv style driveshaft the pinion needs to point at the t-case.
Old February 26th, 2013, 08:15 PM   #3
moparhorse
moparhorse's Avatar
On a 14 bolt, I myself have found out that the pinion bearings dont get enough lube when the pinion is pointed up more than 25-27 degrees. Had two good rear ends burn up on tow vehicle of mine when doing so. The total weight was over 14,000 pounds also, truck/trailer/cargo. To make it last I ended up making a diff cover that held more oil and over filled it also. There a awesome rear end aslong as you keep oil to all 3 pinion bearings. Hope this helps ya
moparhorse is offline   Reply With Quote
Old February 26th, 2013, 08:34 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
How much lift do you have? Can you raise the motor at all to help slope the t case downhill at all so it isn't sitting level? How long is your rear driveshaft? Do you have a lot of droop with your suspension? Just curious what kind of driveshaft angle you are going to end up with when the suspension drops out.
Page generated in 0.19213 seconds with 35 queries
