Vortec 5.7 stumble- miss - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2013, 09:33 AM   #1
bdd1469
bdd
bdd1469's Avatar
Default Vortec 5.7 stumble- miss
Ex gf has a 1999 suburban, she said it started acting up about a month ago and has gotten progressivly worse. It runs fine and then acts like someone switches the ignition off and back on. It bucks and chugs under a load, but not all the time.
It throws no codes .
I replaced the plugs, cap, rotor, and plug wires because I have had several no starts from bad cap on vortec motors.
Fuel pressure is 55-60 psi and doesnt seem to bleed down, but I only left gauge on for about a hour.
I know it probobly needs intake gaskeis. I ran out of brake clean so my next step is getting more and searching for a vacume leak around intake.
Im sure it has dirty injectors and could use the sfi to mpi spider upgrade. I dumped a can of see foam in the brake booster line, shut it off and let it sit for a couple hours. It seems to idle a little smoother, but still cuts out.
I pulled the dist to check out the gear as I have heard horor stories. The dist seems tight, and the gear is fine. I realize the timing needs to be checked, but it runs the same as it did.
I want to do the spider if you guys think it could be my problem, but cant just throw money at it.
Any advice would be appreciated.
The best advice I heard so far was dont work on the ex gfs car.
Old February 3rd, 2013, 10:18 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
just about all the 96-99 vortec engines had this issue. most of the time the injectors stick/are dirty. they can be cleaned for the price of some gaskets, or replaced for around 300 bucks. i am having this same issue with my 99 blazer. i plan on swapping to the better injectors.
Old February 3rd, 2013, 11:08 AM   #3
in2deep
Hole tester
ex gf dont sound like your problem, if you do work on it atleast get paid for parts and give her some
look at injectors
Old February 3rd, 2013, 12:05 PM   #4
frdboy
frdboy's Avatar
I would look at the coil, maybe have someone load it while you spray some water on it.
Old February 4th, 2013, 09:16 AM   #5
bdd1469
bdd
bdd1469's Avatar
Thanks thats a good idea.
Old February 4th, 2013, 09:21 AM   #6
bdd1469
bdd
bdd1469's Avatar
I plan on replacing the injectors and doing a intake gasket, but was hoping to confirm that is for sure my problem first. I dont want to spend 8 hrs and several hundred to find out it's not the problem. I did the sea foam down the pcv line trick hoping it would change something, pointing to a injector issue. It didnt changa anything.
I have read of people with the same symptoms fixing it with different parts. It appears it can be a bad dist, pcm, injectors, fuel press regulator. If it was mine Id just throw parts at it because I like new parts on my stuff. I cant do that here.
Old February 4th, 2013, 09:28 AM   #7
Toyfish
Toyfish's Avatar
Ive had a few 350s act up and it ended up being a bad distributor
Old February 4th, 2013, 10:42 AM   #8
bdd1469
bdd
bdd1469's Avatar
Thanks
I pulled this one. It feels tight and the gear looks good. It does have cracks where the screws hold the cap down, so Im replacing it today with another used one I have. I will have a freind set the cam retard after I do it and see what happeneds.
Old February 4th, 2013, 11:16 AM   #9
bdd1469
bdd
bdd1469's Avatar
Wish me luck!! Found the wire harness that goes to the crank sensor was rubbing on the harmonic balencer. The power steering felt weird at times and the wires going to the pump rubbed through also. Are these a variable pressure pump or something?
I think I may have found my problem.
Old February 4th, 2013, 11:40 AM   #10
frdboy
frdboy's Avatar
Yeah the PS is variable effort. Sounds like you may have it fixed
Page generated in 0.31808 seconds with 53 queries
