1987 S-10 Clutch dilemma - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2013, 09:57 PM   #1
itchy
itchy's Avatar
Default 1987 S-10 Clutch dilemma
Looking for some thoughts on my clutch/trans issue before I pull the trans out of the truck. Here's the issue.
Pushed in the clutch peddle, and it made a hollow pop noise, and I lost the tension on the peddle. I was able to still use the clutch, but it was at the top of the peddle, and would engage with very little pressure. The master and slave cylinders were cheap so I replaced both of those first, hoping for the best......No good. With a new clutch master cylinder, and slave cylinder installed and bled, it seems to be worse, and now the peddle is non existent, and I can't get any tension on the peddle. I could use the clutch before, and now the clutch wont engage at all.
Any ideas. I dont have alot of troubleshooting experience with manual transmission. Do pressure plates just stop working, and cause problems like this? Any thoughts or ideas would help.
Cheers, Keith.
itchy is offline   Reply With Quote
Old January 31st, 2013, 10:50 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
pull the slave cylinder from the trans and use a long extension, push on the throw out fork. it should be very difficult for you to push by hand. if not the pressure plate broke the fingers. not common but i've seen it happen.
Old January 31st, 2013, 10:57 PM   #3
itchy
itchy's Avatar
Thanks.....I'll give that a try tomorrow night.
Old February 1st, 2013, 08:04 AM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
If it's from '87 I would pull the transmission, have the flywheel turned and put a new clutch in. They are cheap.
BigBlockBlazer is online now   Reply With Quote
Page generated in 0.13916 seconds with 35 queries
