92 Jeep Cherokee Laredo *SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2013, 07:16 PM   #1
scooter86
Default 92 Jeep Cherokee Laredo *SOLD*
$500 Firm, will need to be towed
Located in Westland, MI
92 Cherokee Laredo 241,xxx miles
New years eve day this is the issue I was having (not my video but found it on youtube) the next day it would only start and stall in a few seconds.
https://www.youtube.com/watch?v=X77AumVYXCw
I installed a new fuel pump relay and it is starting again, but still running rough.
Possibly TPS or CPS or fuel pump/fuel filter problems is what I think
I have a kid on the way and was in the market for a newer vehicle anyways and when jeep died we picked up another vehicle. I don't feel like putting any money into this.
I have owned since 2010 and was my second vehicle up until summer 2012 when it became my DD. I have only put around 15k on it since owning it. I moved to Westland from Saginaw and have made the 1.5hr trip several times in the jeep.
In 2010 I put a used 4.0 (1995? miles unknown)from member- Special K. All fluids except Transmission were changed, rear brakes replaced, steering stabalizer, oil pressure sensor. 2012 I had new tailpipe installed. Has older CD player installed. 4x4 works great. Decent tire tread. New battery last august.
There is a lot of rust on this including the front suspension and floorboards and at some point they were covered but its due again. One of the wiring harnesses on taillights needs to be replaced. Driver side i believe, as there are no brake lights or signals on that side but running lights work. Has hitch and trailer wiring but hitch will not come out and is slightly bent from trying to yank it out. Driver seat leans back on an angle, I have rear seats folded up to help support it upright. There must have been an ignition short because the key doesn't always work but there is a push button start under dash that will always work. Also the windows will leak a little when in car wash or during heavy rain and the floor will be wet. The driver window will only go down about 2/3 of the way. Cracked windshield.
When it was running the newer motor ran great, transmission shifted great and 4x4(np242 t-case) and brakes all worked good. It does ride rough and interior has alot of road noise though.
would make good beater/first car with a little work or donor vehicle.
EDIT: Added more pics
Driver side front-lower shock mount
Lower driver side control arm mount that my buddy welded 2 years ago
Driver side
Passenger side
patch above muffler
crack in windshield
rear tires
Front tires
scooter86 is offline
Old January 31st, 2013, 08:10 PM   #2
Woodsy44
Woodsy44's Avatar
Can we see some pics of the rust?
Woodsy44 is offline
Old January 31st, 2013, 08:30 PM   #3
scooter86
I can this weekend
Old January 31st, 2013, 08:39 PM   #4
Woodsy44
Woodsy44's Avatar
I'm interested lmk when u get some pics, r the frame rails solid atleast?
Woodsy44 is offline
Old January 31st, 2013, 11:15 PM   #5
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Like to see some pics too, good and the bad.
98ZJ318 is offline
Old February 1st, 2013, 11:52 AM   #6
scooter86
Ttt
Old February 1st, 2013, 11:56 PM   #7
dfreeman616@gmail
dfreeman616@gmail's Avatar
Send a message via AIM to dfreeman616@gmail
how are the tires?
dfreeman616@gmail is offline
Old February 2nd, 2013, 06:47 AM   #8
scooter86
The front 2 are cooper st 's, the rear 2 are both different but all still have good tread life yet. All are 235/75/15
Old February 3rd, 2013, 08:08 AM   #9
scooter86
ttt
Old February 4th, 2013, 12:03 PM   #10
scooter86
Bump
Old February 5th, 2013, 07:40 AM   #11
scooter86
Bump
Old February 5th, 2013, 08:17 AM   #12
ronprice
ronprice's Avatar
by pass the fuel relay see if it starts. I have seen this solve this problem many times. I am interested but have to wait till after the 15th
ronprice is offline
Old February 5th, 2013, 05:47 PM   #13
scooter86
It will start, but it dies within seconds. Also when key is on Acc I can hear the fuel pump running.
Old February 6th, 2013, 02:04 PM   #14
scooter86
Bump
Old February 6th, 2013, 03:31 PM   #15
ronprice
ronprice's Avatar
It is probably priming when you first turn the key then the relay isnt keeping the pump running after it starts. Pull the relay and jump it so pump runs all the time then try to start.
ronprice is offline
Old February 6th, 2013, 04:11 PM   #16
jimhri
jimhri's Avatar
if successful, will this jump the price to $599.99?
jimhri is offline
Old February 6th, 2013, 06:08 PM   #17
scooter86
Yes it started with jumper wire installed. I picked up a new relay and will stay running. But it still seems to want to run a little rough. Could be from sitting in this weather for a month without being ran. I will run it for a few tomorrow and get a video
Old February 7th, 2013, 09:23 AM   #18
ronprice
ronprice's Avatar
Told you it would work.
ronprice is offline
Old February 7th, 2013, 01:33 PM   #19
scooter86
Thanks RonPrice for the advice. Jeep is starting every time now, but idling rough and hesitant to rev up sometimes. Would be able to drive onto trailer, but not to drive it home.
Having a hard time getting a video uploaded.
Old February 8th, 2013, 08:34 PM   #20
scooter86
Ttt
Page generated in 0.45858 seconds with 83 queries
