Bumper build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2013, 07:30 PM   #1
Bryan289
Bryan289's Avatar
Default Bumper build
Ok, I've been thinking about some bumper builds for my F-150 and here's one of them, an air tank for a rear bumper.it would go the whole width of the truck but I'm not really sure how to do it so it would look right. Any ideas?
Bryan289 is offline   Reply With Quote
Old January 29th, 2013, 08:06 PM   #2
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Try again on those pics
Old January 29th, 2013, 08:14 PM   #3
Bryan289
Bryan289's Avatar
Gotta do it at school
Old January 29th, 2013, 08:19 PM   #4
Deuling
Sand Slut
Deuling's Avatar
How big are you thinking??
Why not just put an air tank up under the box and make some much less ugly bumpers.
I have only built one rear bumper, idk where my pics are, but heres a couple front ones.
How you guys like the bumper? - Great Lakes 4x4. The largest offroad forum in the Midwest
Done a couple more but dont feel like finding the pics lol
Deuling is offline   Reply With Quote
Old January 29th, 2013, 08:23 PM   #5
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
right click on the pic then copy image URL, then click on the little mountain picture then paste the url in the box. Then it will show up
Old January 29th, 2013, 08:30 PM   #6
Bryan289
Bryan289's Avatar
I don't want it huge, but I figured I could kill two birds with one stone this way
Old January 30th, 2013, 05:19 AM   #7
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Makes sense putting pressurized air in the thing that is most likely going to take most of the impact if you crash.
Old January 30th, 2013, 06:09 AM   #8
Bryan289
Bryan289's Avatar
Well it's not going to be thin metal, it's going to be strong
Old January 30th, 2013, 01:03 PM   #9
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
What are you going to do for a compressor?
Old January 30th, 2013, 04:52 PM   #10
chadcooper55
How are you going to weld it? Are you using pipe or plate? If you are using pipe are you using end caps or plate?
Unless you are a certified welder and have a clue about how to do it correctly it is a terrible idea.
Old January 30th, 2013, 05:35 PM   #11
2fst4you
2fst4you's Avatar
Would be cool if you could pull it off but I can't see building a decent looking bumper that is big enough to hold a worthwhile amount of air. Plus it must be sealed perfect and you must have compressor
Old January 30th, 2013, 05:50 PM   #12
Bryan289
Bryan289's Avatar
The main problem is have is getting it to seal, I could figure out the compressor or I could just put a gauge on it, and fill it up with air before I leave home. And the only way that I could see it being a problem with the compressed air is if I smack down on a rock, and even then it would blow up, maybe just get a hole and let the air out, it couldn't hold enough to explode.
Old January 30th, 2013, 06:09 PM   #13
chadcooper55
Default Re: Bumper build
you are dumb. If you can't make it seal you have no business even doing it.
You have no clue either. If a cap or something came off it can turn into a cannon. There is more energy in there than what you think. I weld high pressure pipe for a living and I have seen the aftermath of explosions. Just think about if you took a bicycle pump and pumped it up to 150 psi. How much energy would you physically have to exert to do that? That is the same amount that would be coming out instantaniously. I wouldn't worry about a puncture as much as a failed weld.
Old January 30th, 2013, 06:48 PM   #14
2fst4you
2fst4you's Avatar
You are dumb and apparently cant read I said it must be sealed perfect
Old January 30th, 2013, 06:54 PM   #15
deerebowtie
Unchained
deerebowtie's Avatar
watch a punkin chunkin video - it shows the power of what you're contemplating.
if you have to have oba on the cheap, get a hp steel 120 cu ft scuba tank, or power tank of some kind, or rig your ac compressor. Plenty of air whenever, and little to no risk maiming or killing someone.
Old January 30th, 2013, 07:10 PM   #16
Bryan289
Bryan289's Avatar
Who says in gonna have 150 psi, and what do you think I'm making this out of, 1/16th steel? I know it will hold up to what I need
Old January 30th, 2013, 07:15 PM   #17
chadcooper55
I would say that is a given.
Old January 30th, 2013, 07:20 PM   #18
chadcooper55
I wouldn't be concerned with the metal, I would be concerned with the weld.
Old January 30th, 2013, 07:23 PM   #19
silveradoboy
Sam Brown
silveradoboy's Avatar
Work on building a front bumper for that pretty new winch of yours!
silveradoboy is offline   Reply With Quote
Old January 30th, 2013, 07:24 PM   #20
Bryan289
Bryan289's Avatar
The weld will be fine, after its done I'm going to test it to make sure there are no leaks, I know the welder, haven't seen a bad weld from him yet.
Page generated in 0.36444 seconds with 84 queries
