3.4L 4runner running condition. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 28th, 2013, 11:10 AM   #1
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Default 3.4L 4runner running condition.
I've noticed if i dont let my yota warm up before taking it off it runs like poo. No power and almost sounds like its popping through the exhaust? But it runs like a champ once it warms up and is fine? Sensor? Clogged cat?
98ZJ318 is offline   Reply With Quote
Old January 28th, 2013, 12:32 PM   #2
BOGDOG
BOGDOG's Avatar
Never had the issue with mine but if it were a clogged cat I don't think it would go away after it warms up. Sounds like a sensor. Check engine light on at all? Have you tried to pull codes?
Old January 28th, 2013, 05:15 PM   #3
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Not yet, went too but one place the scanner couldnt read or connect and the other place's was broken so maybe tomarow.
Old January 29th, 2013, 10:36 AM   #4
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
PO120 TPS malfunction
PO125 Closed loop fuel control insuf coolant temp.
PO130 02 ckt malf.
PO133 02 ckt slow to respond.
PO440 Evap malf.
Where to start?
Old January 29th, 2013, 12:12 PM   #5
BOGDOG
BOGDOG's Avatar
You said it goes away after it warms up. I'd check out the insufficient coolant temp. Is the thermostat working properly? radiator full of coolant?
Old January 29th, 2013, 12:20 PM   #6
huntertim214
huntertim214's Avatar
had a similar issue with my 94 YJ... when I first started it and gave it gas it would pop and lunge and then finally "work through it" and get up to speed. didn't do it after warming up. I replaced a number of parts chasing it, including cat and exhaust, fuel filter, TPS, etc. but it turned out to be a cheap O2sensor and 15 minutes of labor.
huntertim214 is offline   Reply With Quote
Old January 29th, 2013, 01:05 PM   #7
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Yes i believe the thermostat is working properly and the radiator is full of coolant.
Thinking it might be both, the tps and 02 sensors. i'll prob end up replacing both.
Old January 30th, 2013, 12:36 PM   #8
BOGDOG
BOGDOG's Avatar
What about the Temp sensor. Have you checked out IH8MUD or any of the other Toyaota sites for info?
Old January 30th, 2013, 06:26 PM   #9
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Yeah, I'm a member on t4r.org. Couple guys said it sounds like the 02's are causing the issue and creating more problems.
Old January 30th, 2013, 07:59 PM   #10
Rattler
Home Sweet Homicide
Rattler's Avatar
For tech stuff I always go to TTORA.
Page generated in 0.19074 seconds with 53 queries
