Stroked 2000 Grand sold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2013, 08:38 PM   #1
Axe Lip
Go Lions
Axe Lip's Avatar
Default Stroked 2000 Grand sold
SOLD 2000 Grand cherokee trade for guns and cash:)
235k on body 56k on motor replaced by p/o with a 4.6l stroker MAHLE hypereutectic pistons, MAHLE Original moly piston rings,
Clevite engine bearings, Melling oil pump, 7120 (91-95) cylinder head, 4.2L crankshaft and rods. jeep has Magnaflow muffler with off-road pipe & stock 3.55:1 gears
just put in a newer tranny with 79k w/ fresh electronics with receipt
also have all maintenance records from the P/O
leather interior from a 2004 limited switches are in for the heated leather but the seats are not wired
has brand new tires 245\70\16 bfg a/t
All items below were replaced by the P/O last year
-Rear u-joints
-Fan relay kept burning out so I bypassed it with a dash switch
-Passenger side wheel bearing assembly
-Vacuumed out old pag oil and refrigerant, refilled nice cold AC
-All window belt moldings
-steering damper
-all 4 tie rods
-front brake pads and slotted front rotors
-Passenger side front axle shaft
- All 4 shocks
- added external transmission cooler
- Front end alignment was done this spring
jeep has power windows and doors comes with a working key fob
It does have a cracked windshield does not leak and the service light is on due to the cat being removed so the rear o2 reads bad
I was driving this jeep everyday with no issues went on 2 long trips up north this past fall no problems. jeep always starts and motor runs very strong with plenty of torque.
averages 15.5 mpg 19-20 on e way
body has some small dings scratches and minor surface rust in a spot
Or 2 with one good one dent on pass rear quarter in picture should pull right out just never cared to do it.
hood has typical clear coat problems
if your looking for a driver or a vehicle to lift for off-roading this would be great for you
bought this in late summer/early fall from another gl member as a winter ride but got a deal on a 2013 sierra lease I could not pass up so I no longer need this and dont have time for to turn it into a project
asking $2,900 obo sold
Will accept up to $1500 in guns
Axe Lip is offline
Old January 28th, 2013, 08:57 AM   #2
Axe Lip
Go Lions
Axe Lip's Avatar
ttt
Axe Lip is offline
Old January 29th, 2013, 10:06 AM   #3
Axe Lip
Go Lions
Axe Lip's Avatar
Bump
Axe Lip is offline
Old January 29th, 2013, 03:04 PM   #4
trogdor48430
trogdor48430's Avatar
nice jeep, if i had the cash id pick this up
trogdor48430 is offline
Old January 30th, 2013, 02:11 PM   #5
Axe Lip
Go Lions
Axe Lip's Avatar
Bump
Axe Lip is offline
Old January 31st, 2013, 07:20 AM   #6
Axe Lip
Go Lions
Axe Lip's Avatar
2,900 obo
Axe Lip is offline
Old January 31st, 2013, 04:46 PM   #7
jp4whln12
Tiny Member
jp4whln12's Avatar
bump for a good looking jeep.
jp4whln12 is offline
Old February 1st, 2013, 07:48 AM   #8
Axe Lip
Go Lions
Axe Lip's Avatar
Ttt
Axe Lip is offline
Old February 2nd, 2013, 09:54 AM   #9
Axe Lip
Go Lions
Axe Lip's Avatar
Ttt
Axe Lip is offline
Old February 4th, 2013, 10:50 AM   #10
Axe Lip
Go Lions
Axe Lip's Avatar
Pending
Axe Lip is offline
Page generated in 0.29434 seconds with 54 queries
