TBI ISsue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2006, 10:17 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default TBI ISsue
Fires, runs for a second, dies, repeat. shot ether in the TB, started a small fire, but still does the same thing, when I have it running on ether though it runs smooth and even when its running for the second or two on gas its smooth.
I hear the fuel pump, it was replaced and has very few miles on it... maybe 4k
fuel filter was done with the pump
cap and rotor and wires were also all changed at that time. The vehicle has been parked for a year and a half however and I just ran it down the road and around the block a month ago and it was fine then.
Sometimes I get a couple seconds..... can also keep it running with ether.
Doesn't appear to be flashing any codes either
also new battery -- that is the only thing that changed since I last ran it.
I am stumped/pissed as I was bringing it back to my house tonight and it started pouring as I was wrestling with it.
Old October 28th, 2006, 12:06 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
check your vacuum lines, I just had that issue
Old October 28th, 2006, 08:05 AM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
lol...x's2 but don't rule out the pump I went thru this on a year old pump for the blazer. Check the spray pattern out of the injectors mine only misted out of one when it was acting up. And you could do a pressure test for the fuel. Finally if all checks out. if you have a spare mapsensor laying around I would check that.
Old October 29th, 2006, 12:42 AM   #4
jeepfreak81
81 inches of fun
Thanks, I will look at that stuff... the only thing it had was a slight hesitation, while cold, and it had that when I parked it... I gotta wait for the rain to stop now...
Old October 29th, 2006, 03:21 AM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
by the way you can look at the spray pattern with a timming light. it should be a nice cone shape. if its drippy or has droplets in it then look at fuel presure. secondly use carb clean to keep it running if you think its starved for fuel. it will run smoother.
Yetti
Old October 29th, 2006, 01:04 PM   #6
jeepfreak81
81 inches of fun
its running and you can see the injectors firing (I have tried 2 sets) it idles... literally for about 2 seconds, the injectors shut off and it stalls. Appears plenty of fuel is coming from the fuel pump, but I dont have a pressure tester for it.
Old October 29th, 2006, 07:19 PM   #7
jeepfreak81
81 inches of fun
got it running, replaced the oil pressure sensor/fuel shutoff and it was still doing it... kept dicking with it and tapping stuff under the hood and it started running again
Old October 29th, 2006, 08:51 PM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Sandals went through this a month or two. Take a look at his thread, it seems like this sounds familiar.
JohnnyJ is online now   Reply With Quote
Old November 5th, 2006, 10:48 PM   #9
jeepfreak81
81 inches of fun
MFER went over there and it is doing it again GDAMN IT!!! It ran perfectly when I last was there, now it runs and I get 5-10 seconds and the fuel shuts off Before that spray pattern is fine and it will even rev and run normal... after 5-10 seconds the fuel is cut off to the injectors and it stalls
Old November 8th, 2006, 07:26 AM   #10
BigBlueBurban
Temporary Web Wheeler
BigBlueBurban's Avatar
sounds more like some tempermental woman to me... check the wiring for the injectors/fuel pump and any related - you may have something shorting out somewhere
BigBlueBurban is offline   Reply With Quote
Old November 8th, 2006, 11:25 AM   #11
jeepfreak81
81 inches of fun
I would think so too, only when it ran I beat the snot out of it down a rough dirt road and it didn't cut out once... parked it and now its doing it again.... Been over most of the wiring and have not found anything yet
Old November 9th, 2006, 01:34 PM   #12
jeepfreak81
81 inches of fun
does the 89 with TBI have a MAF sensor?... My dad and I were thinking maybe, but cannot find anythign that resembles one... normally it would be in the air cleaner, but not on here if it does
Old November 9th, 2006, 10:22 PM   #13
jeepfreak81
81 inches of fun
looks like it was the fuel pump relay... guess I will find out in a couple days when I go back to pick it up
Old December 10th, 2006, 08:10 PM   #14
cjshawn
Send a message via Yahoo to cjshawn
I would look at the ignition module under the distributor cap. It controls spark and fuel. I have had dozens of them go out on trucks at work. Sometimes it would run for an hour before dying, sometimes it wouldn't start at all. They take all of 10 minutes to change and are pretty cheap.
cjshawn is offline   Reply With Quote
Page generated in 0.34537 seconds with 65 queries
