Stumpy the yota build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2013, 08:00 PM   #1
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Default Stumpy the yota build
I bought this 86 4runner in feb 2008 and never did a build thread for it. So here it is when I bought it.
I started the same way most do ,add a bunch of bolt on stuff
I added a bumper and winch, a soft top sliders and some super sweet dick cepek dc1 's with pro comp 31" tires. It looks gay now to me but I thought it was cool then
I wheeled it like this for a little while then I thought ,I will improve it by.........wait for it. Bigger tires! Yep 35" boggers. There is nothing a tired 280k 22re engine would like more than a set of boggers.
They actually worked pretty good and I kept them for a bit. I found some more $ and added some dual cases with a twinstick and a hand throttle for the technical stuff. I love this mod!
I wanted to make it perform better and decided not to worry about the streetablity as much so I did a solid axle swap and longer rear springs. And some 30 spline cryo axles in place of the stock birfields.
I rocked it like this for a while. It wheeled well off road and was surprising on road.
It had it's limitations
I did 5.29 gears and a spool in the rear . That was a huge difference. Then I wanted bigger tires and something that wont dig as much so...... I got these.
Some 39.5 Pitbull Rockers and some Trailworthy Fab beadlocks
I cut the living crap out of the fenders and firewall to clear these. I also took off the gay fender flares. I bent some tubing to protect the sides and welded them on . I also needed some support for my huge penor stinger ,so it doesn't flex when I'm hanging off it for the stinger sexy pics so i welded some tubes to the frame for it also.
I added some onboard air useing my air conditioning compresser.
I wanted something different than the tube doors so I thought why not cut up your perfect factory doors with power windows. So I did.
All done
They turned out nice , and my hair can blow in the wind on those nice summer nights.
Then it rained, and I am delicate so I took the cut out section and made some inserts with snap in windows .
I am very happy with what my truck does offroad now except I was sick of dargging it's ass over every obstacle. So I bobbed the back 12" it was a major pain but well worth it in departure angles. And I was able to fix my shackle angle since I had to move the shackles to clear the tailgate .
The start
no turning back now
almost done
done
opening tailgate too!
before
after
It wheels so much better now!
Well that's about all for now. I am going to do a hydro assist and lunchbox lock sometime soon . I have a 4.3 vortec engine to install too . I just need some time and $ for both .
stereoguy is offline   Reply With Quote
Old January 25th, 2013, 08:04 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Nice looking 4runner!
Old January 25th, 2013, 08:10 PM   #3
1 ton tj on 40's
1 ton tj on 40's's Avatar
looks nice good work
Old January 25th, 2013, 09:04 PM   #4
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Thanks. It is a work in progress.
Old January 25th, 2013, 09:32 PM   #5
1997XJ
1997XJ's Avatar
Not usually a yota fan but i really do like this one! Nice work.
1997XJ is offline   Reply With Quote
Old January 25th, 2013, 09:36 PM   #6
curbdog17
Mini Van
curbdog17's Avatar
Nice build
Old January 25th, 2013, 10:03 PM   #7
KCameron13
Weekend Warrior
KCameron13's Avatar
Very cool build and some quality fab work on your part. Nice job!
KCameron13 is offline   Reply With Quote
Old January 26th, 2013, 12:17 AM   #8
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Dam that's clean.....little tall for my tastes but still very nice.
Make sure you upgrade the knuckle studs.....at this point its not if but when your gonna rip the knuckle off. Hub studs too. There are pics of all the upgrades i did on mine in my build thread.....any questions on that or the assist i can try to share what i have learned along the way.
Old January 26th, 2013, 08:53 AM   #9
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Thanks! I was going to do a TJ but my family wouldn't fit in it (5 people). Although ,it's kinda funny cause they never come with.
Old January 26th, 2013, 09:00 AM   #10
stereoguy
2jz NO SH*T!
stereoguy's Avatar
I did the arp magnum studs on the steering arms and arp hub studs and the cryoed hub gears when I did the 40"s cause I knew what was coming I am probably going to do the hydro assist next. And maybe the 6shooter knuckles. I really want a locker in the front but steering would be bad now, so I think hydro first. What hydro assist are you running?
Old January 26th, 2013, 09:49 AM   #11
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am not entirely sure since it was on the truck when i got it.
I believe it is from trail gear.....i put a cooler and bigger reservoir on it and it works pretty decent.....my only complaint is its a little slow.....99% you never notice it but i ran a comp at bundy hill and trying to dodge trees at speed it was entirely possibly to over drive the steering.
If i were starting with nothing i would go full hydro and never look back
Old January 26th, 2013, 10:18 AM   #12
tgmaul
tgmaul's Avatar
$runner looks sick, Im sure you could make the rubicon super easy now only prob is its 2700 miles away., sweet rig, not to many yota head up here in michigan, glad to see someone do this with a yota got any spare parts?
tgmaul is offline   Reply With Quote
Old January 26th, 2013, 10:44 AM   #13
stereoguy
2jz NO SH*T!
stereoguy's Avatar
I'm kinda scared to do a full hydro, it's not fast anyway so I'm going to keep it a assist I'm pretty sure it only has about 80 hp now but those little ponies can do a lot
Old January 26th, 2013, 10:49 AM   #14
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Not too many spares other than stock stuff. I'm a throw away kind of guy not a keep it . Sorry Thanks on the compliment. It's funny that it turned out nice looking ,I just kept adding stuff and improving it and that's the result. I like being a little different and yota's are so bulletproof . 280 k miles and still doesnt burn or lose a drop of oil
Old January 26th, 2013, 11:12 AM   #15
ATVLIFESTYLE
ATVLIFESTYLE's Avatar
Hey you finally did a build.
Did you decide certain previous mods were gay or did certain people remind you of it daily ?
ATVLIFESTYLE is offline   Reply With Quote
Old January 26th, 2013, 11:40 AM   #16
hightech
Crawl 101
hightech's Avatar
NICE work !!!
hightech is offline   Reply With Quote
Old January 26th, 2013, 01:26 PM   #17
hellspawn
hellspawn's Avatar
Nice build
hellspawn is offline   Reply With Quote
Old January 26th, 2013, 06:59 PM   #18
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Fag! I'm always on the cutting edge! Haters gonna hate!
Old January 26th, 2013, 09:48 PM   #19
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Nice 4 runner build.
Old January 27th, 2013, 06:49 AM   #20
RADRICK
RADRICK's Avatar
Damn mike it has came a long way. Really like the tube work, and bob tail.
Page generated in 0.49502 seconds with 83 queries
