1971 Bronco w/ 99 302 FI needs a tune? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2013, 07:48 PM   #1
firehawk
Live Action!
firehawk's Avatar
Default 1971 Bronco w/ 99 302 FI needs a tune?
My 71 bronco runs and drives great but the fumes out the exhaust are going to kill me. Seems to be running rich.
Not 100% sure about the o2 sensors functioning correctly. I need to scan codes again to see what they are and if they have anything to do with it.
Motor is 302 from a 99 Mountaineer as is the trans.
I did not put together the FI parts, they were on it when I got it but are from a 5.0 Explorer.
I fought with the harness the PO put in it, he is an engineer but not a mechanic at all....
I swapped it with a Ford Racing harness I got from Bigbchevy, its probably his fault.
I just bought a used wideband and plan to install and see where the ratio is at, any recommendations on where to put it, I only have one sensor. Will I need to monitor both sides one at a time?
Just need to know where to start.
If you know of a link to steps to take I can follow directions, I think.
Old January 23rd, 2013, 08:18 PM   #2
Bones
Bones's Avatar
You should probably get rid of it (and check your email)
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 23rd, 2013, 09:28 PM   #3
frdboy
frdboy's Avatar
I would start by getting a scanner on it and make sure everything is working correctly, fuel trims are close, o2's working and so on. If it is a stock motor there should be no reason for a "tune".
Old January 24th, 2013, 07:52 AM   #4
firehawk
Live Action!
firehawk's Avatar
But is seems soo rich. It doesn't have cats on it either. Might put one or two on it this year.
I will scan it and see what it comes up with.
Old January 24th, 2013, 07:54 AM   #5
firehawk
Live Action!
firehawk's Avatar
Not ready to part with it yet, unless the price is right.
Old January 24th, 2013, 08:01 AM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
You'll be fine with the O2 on one bank. You want to install it like this:
http://www.wbo2.com/lsu/position.htm
Old January 24th, 2013, 08:10 AM   #7
firehawk
Live Action!
firehawk's Avatar
Thanks
Page generated in 0.21451 seconds with 44 queries
