97 Sunfire FI issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2013, 12:16 AM   #1
firehawk
Live Action!
firehawk's Avatar
Default 97 Sunfire FI issue
Working on a friends 97 sunfire.
It has been running on 3 cylinders for at least 5 years.
I put a muffler on it for her after some fool stole her catalytic converter, it was a bit loud even before that.
The metal crossover tube rusted a hole through it so she brought it by today.
I looked over most of the 280,000 mile set of wheels she drives.
Found that one of the injectors is not firing, probably the computer.
I can get a reman one from Oreilly for $80 and it needs to be flashed. Is that done at the dealer? Or can that be done with a tech2?
I would like to get it running better for her. It runs pretty good on 3 cylinders but that is the kind of crap that bothers me if it can be fixed.
I did a comp test and two of the cylinders are about 175psi and two are maybe 125psi, but again it runs pretty well.
I welded the holes in the crossover tube until I can get a price on a new one and it seems it might be a dealer only item as I could not find in online. And I wanted to make sure it still ran ok after she drove it and possibly overheated it.
Can a used computer just be swapped in or will it need to be flashed too?
Thanks, Jay
Old January 23rd, 2013, 12:24 AM   #2
buttercr125
I work out
buttercr125's Avatar
More than likely not the computer...they have a wiring issue in the passenger fender well where the PCM is located at.
Old January 23rd, 2013, 01:57 AM   #3
Toyfish
Toyfish's Avatar
Yup i agree the last one i fixed was a broken injector wire at the pcm wich like he said is in the passenger fenderwell start there before buying parts
Toyfish is online now   Reply With Quote
Old January 23rd, 2013, 11:25 AM   #4
firehawk
Live Action!
firehawk's Avatar
Will take a look, thanks.
Page generated in 0.20084 seconds with 35 queries
