96 Jeep wont blow hot air - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2013, 09:08 PM   #1
jdeff87
jdeff87's Avatar
Default 96 Jeep wont blow hot air
I have a 1996 jeep grand Cherokee Inline 6, 4.0. it blows Luke warm air not hot like it use to. I'v had the water pump changed. The lines to the heater core don't get hot and are soft. Along with the hose that comes from the radiator and goes into the block is not hot and also soft. radiator cap is also not hot. any ideas?
jdeff87 is offline   Reply With Quote
Old January 22nd, 2013, 09:17 PM   #2
rentalrider
rentalrider's Avatar
What's temp reading? Sounds like your thermostat is bad/stuck open. Much better than closed!
Old January 22nd, 2013, 10:05 PM   #3
firehawk
Live Action!
firehawk's Avatar
Or your heater core is clogged.
Thermostat and coolant flush should get you what you want.
Old January 23rd, 2013, 07:20 PM   #4
mzy4v1
40's baby!
mzy4v1's Avatar
I am going to ask the obvious question...is is topped off with coolant. The radiator was leaking in my wife's XJ, the coolant level got low enough that it had exactly the same symptoms you are describing.
mzy4v1 is offline   Reply With Quote
Old January 23rd, 2013, 07:37 PM   #5
firehawk
Live Action!
firehawk's Avatar
Good point!
Old January 23rd, 2013, 08:35 PM   #6
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
also a bad radiator cap will cause all you describe but the t-stat is the most likely culprit
HPandThrottle is offline   Reply With Quote
Old January 23rd, 2013, 09:17 PM   #7
jdeff87
jdeff87's Avatar
Its running about 190 to 200 degrees like it always has. had a flush done not to long ago when i had the water pump replaced. all new coolant and its topped off with coolant. if the thermostat was stuck open wouldn't it take a while for it to get up to running temp? could the blender door have anything to do with the heat?
Old January 25th, 2013, 09:09 AM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
While the blend door could affect the temperature INSIDE the vehicle, it will not affect the temperature of the heater hoses or upper radiator hose.
You should not be able to hold onto the hoses once the vehicle warms up (too hot).
Sounds like a thermostat issue. It could be something from changing the water pump stuck in the thermostat (gasket?).
A plugged heater core won't cause the upper hose to be soft and warm. A soft hose is usually a pressure issue (not building any).
Dumb question, but is it possible they put the wrong water pump on? (spinning the wrong way?)
Old January 25th, 2013, 09:12 AM   #9
firehawk
Live Action!
firehawk's Avatar
Blowing hot air is a womans job anyway
Old January 25th, 2013, 10:47 AM   #10
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Was it warm before the new water pump? Have seen a few reverse flow water pumps that caused this problem.
GNJEEPN is offline   Reply With Quote
Old January 25th, 2013, 02:46 PM   #11
snboarder113
snboarder113's Avatar
Definitely sounds like a thermostat, simple easy job.
snboarder113 is offline   Reply With Quote
Old January 25th, 2013, 02:58 PM   #12
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
This is starting to be a common question on all 4.0's that I have seen in the last month or so. (about 7 total) Every one of them had an air bubble, from recent cooling system repair.
On a 4.0, top it off at the radiator cap, and then pull your heater hose. Continue to fill through the heater hose until you see coolant coming up through the barb on/near the thermostat housing. This means your heater core is now full. I just recently added a gallon of coolant to an XJ that ran fine for temp, but would not give off any heat. (2 actually)
Old January 25th, 2013, 03:11 PM   #13
montecarlo33
The Violator
montecarlo33's Avatar
looks like I also found why my heat sucks!
Old January 25th, 2013, 06:20 PM   #14
firehawk
Live Action!
firehawk's Avatar
Or use a vacuum filler.
Old January 25th, 2013, 07:14 PM   #15
jdeff87
jdeff87's Avatar
problem solved thanks everyone
Old January 25th, 2013, 08:10 PM   #16
GREASYHANDS
GREASYHANDS's Avatar
And?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old January 25th, 2013, 09:22 PM   #17
jdeff87
jdeff87's Avatar
I took both of the hoses that went to the heater core, used a air compress or blew all the coolant out. bought some oven cleaner sprayed it into a bottle mixed some water into it poured it in one hose until it came out the other end. let it sit for about 10 mins. blew all of that out and repeated with just water 4 or 5 times to clean it out.( Lots of gunk came out) filled back up with antifreeze and blowing hot air like it use to.
Old February 5th, 2013, 10:56 AM   #18
1ATony
1ATony's Avatar
This happended to my 97 ZJ when I first got it. I took the two heater hoses off and flushed both pipes out going into the heater core with water, you should have seen the gunk fly out.
Now the heat will melt your eye brows off...lol
1ATony is offline   Reply With Quote
Tags
heating, jeep
Page generated in 0.33033 seconds with 77 queries
