Deulings' dune runner K5 - Page 18 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 13th, 2014, 09:44 PM   #341
Deuling
Sand Slut
Deuling's Avatar
Deuling is offline   Reply With Quote
Old May 14th, 2014, 12:16 AM   #342
Wramblerguy
Wramblerguy's Avatar
Drum brakes??
3rd generation jeeper
Old May 14th, 2014, 05:05 AM   #343
jhnyquest
goof ball
jhnyquest's Avatar
More pics of redhead
Old May 14th, 2014, 06:54 AM   #344
Deuling
Sand Slut
Deuling's Avatar
Originally Posted by Wramblerguy View Post
Drum brakes??
Yah I already dumped $1200 into the axle. I just wanted it in.
Plus I'm not sure if there are any disk setups that will clear my 15" wheels. The whole purpose of the semi float was to stay with my 6 lug 15" wheels.
Lol maybe when I get her out working on it more.
Old May 14th, 2014, 07:00 AM   #345
clarkstoncracker
lol
clarkstoncracker's Avatar
Did you end up putting in shock absorbing bump stops? If so, which one did you go with? How were the results?
Old May 14th, 2014, 07:27 AM   #346
Deuling
Sand Slut
Deuling's Avatar
The air bumps? I did in the front. I went with some used fox 2.0s. I'll never buy used again though unless I saw them in person first. Guy said the shafts were perfect but they had a bunch of spots in them and you could see sand paper lines in it where he tried to make it look better.
Any ways they seem to work ok but I still only have like 8" travel shocks up front so they are really limiting my travel and use of the bump stops. Hope to get my other fox shocks on the front this summer. And see what it will do.
I'd like to run some in the rear as well when I get some extra $$.
Old May 14th, 2014, 09:09 AM   #347
Wramblerguy
Default Deulings' dune runner K5
Weld on allstar brackets with the same calipers you have on the front
I ground down the pads/caliper/bracket to sit closer to the axle and it clears both sets of my 15" wheels
Old May 14th, 2014, 09:14 AM   #348
Deuling
Sand Slut
Deuling's Avatar
Good to know! Thanks!
Down the road I may play with it. For now I only put like $30 into the drum setup to go through and put fresh springs and shoes in. So I'm not at a big loss.
Is that a 14sf?
Old May 14th, 2014, 09:16 AM   #349
Wramblerguy
It's a wagoneer Dana 44 but I would think it would still work
May require a little diferent bracket
But if I remember right I only spent $200 on brakes
That's front and rear with no cores
Old May 14th, 2014, 09:23 AM   #350
Deuling
Sand Slut
Deuling's Avatar
Dang not bad at all!
So you just bolt the caliper to the bracket and set it on the rotor and weld the bracket where it lands? Doesn't sound too bad.
All my fancy stainless spacers I had cut will go to waste now if I do that lol.
Old May 14th, 2014, 10:05 AM   #351
Lousypirate
Whoop Whoop
Lousypirate's Avatar
aa-mfg made me weld on brackets, paid something like $10 or $20 for them.
Go with generic braided -4 flex line, cheap and effective.
I had $60 into my brake swap (not counting pads/rotors/calipers... pulled them off a 10 bolt front)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old May 14th, 2014, 10:29 AM   #352
Wramblerguy
Ya I paid like $18 a piece for brackets I think
And with the weld on you apply air to the caliper so it clamps to the rotor and self centers
It isn't exactly easy but works
Old May 14th, 2014, 10:37 AM   #353
All5ofus
All5ofus's Avatar
Nice Work
All5ofus is offline   Reply With Quote
Old May 19th, 2014, 10:11 AM   #354
Deuling
Sand Slut
Deuling's Avatar
Prepping for this weekend! Anybody else gonna be on the dunes? Made an antiwrap this weekend.
1.5" dom with 1.75 sleeved over the ends.
Old May 19th, 2014, 10:12 AM   #355
Deuling
Sand Slut
Deuling's Avatar
[/URL]
Old May 19th, 2014, 04:58 PM   #356
89TBIguy
slowly but surely
89TBIguy's Avatar
Nice work on the anti-wrap.
89TBIguy is offline   Reply With Quote
Old May 19th, 2014, 10:33 PM   #357
Deuling
Sand Slut
Deuling's Avatar
Thanks dude. You coming up this weekend?
Old May 20th, 2014, 05:34 AM   #358
ljense8
Web Wheeler
ljense8's Avatar
Looking real nice. Should be a load of fun in the sand.
Sent from my SCH-I545 using Tapatalk
ljense8 is offline   Reply With Quote
Old May 20th, 2014, 05:49 PM   #359
89TBIguy
slowly but surely
89TBIguy's Avatar
I wish, Ill be doing my floors all weekend
Ill be up there the weekend of june 27th tho.
Old May 20th, 2014, 06:30 PM   #360
Deuling
Sand Slut
Deuling's Avatar
You should try for the weekend of July 26th-28. Having a big ck5 blazer dune party with guys from all over. Jersey, boston, canada, Iowa, Colorado
Tags
k5, silver lake
Page generated in 0.60680 seconds with 84 queries
