Deulings' dune runner K5 - Page 17 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2013, 02:54 PM   #321
Deuling
Sand Slut
Deuling's Avatar
Just gonna leave this here... The ending is the best part
Deuling is offline   Reply With Quote
Old March 4th, 2014, 10:02 AM   #322
k5jess
k5jess's Avatar
Are you taking my 10bolt or not?
k5jess is offline   Reply With Quote
Old March 4th, 2014, 12:05 PM   #323
Deuling
Sand Slut
Deuling's Avatar
Lol.
Idk. Is it worth it? If I'm gonna run a ten bolt to get by while building the 14, why not fix up my ten bolt that already has the fancy shock mounts. And save money by not buying u bolts, and then buying u bolts again for a 14?
I mean if your gonna drive over, I'll take it. But I don't know if gas to go get it is worth it...
Old March 5th, 2014, 06:15 AM   #324
blazerk5.3
I need a 10 bolt...
blazerk5.3 is offline   Reply With Quote
Old March 11th, 2014, 05:53 PM   #325
k5jess
k5jess's Avatar
Originally Posted by blazerk5.3 View Post
I need a 10 bolt...
Pm me
Old March 11th, 2014, 05:58 PM   #326
Deuling
Sand Slut
Deuling's Avatar
Oh yah I forgot. I'm not messin with ten bolt.
Im putting the 14sf in. Even if it takes longer to build.
Old March 11th, 2014, 07:52 PM   #327
jhnyquest
goof ball
jhnyquest's Avatar
Why go sf instead of ff?
Old March 11th, 2014, 08:39 PM   #328
ljense8
Web Wheeler
ljense8's Avatar
Sf is an easier install. Also, for what he is building his K5 for, sf should be plenty.
Sent from my SCH-I545 using Tapatalk
ljense8 is offline   Reply With Quote
Old March 11th, 2014, 08:41 PM   #329
jhnyquest
goof ball
jhnyquest's Avatar
Explain to me how the sf is easier to install?
Old March 11th, 2014, 09:05 PM   #330
Deuling
Sand Slut
Deuling's Avatar
I already have the 14 swap kit from ruffstuff, so perches etc will be easy.
I'd like ff. but this is a 6 lug axle so I get to keep my wheels and tires.
Also the axle is free moneywise. Just have to help link my buddies rig as cost.
Old March 11th, 2014, 09:15 PM   #331
jhnyquest
goof ball
jhnyquest's Avatar
I see.
Old March 11th, 2014, 09:28 PM   #332
Deuling
Sand Slut
Deuling's Avatar
I see.
In the market to do more driveshafts? Got some rigs that are gonna need them.
Old March 11th, 2014, 09:30 PM   #333
jhnyquest
goof ball
jhnyquest's Avatar
Always
Old March 11th, 2014, 10:21 PM   #334
Deuling
Sand Slut
Deuling's Avatar
Always
Cool. When we get the suspensions set and get measurements I'll get with ya.
Old March 12th, 2014, 06:13 AM   #335
jhnyquest
goof ball
jhnyquest's Avatar
Okay
Old April 7th, 2014, 08:35 PM   #336
Deuling
Sand Slut
Deuling's Avatar
Dug her out
30 spline shafts (long side is an alloy shaft) and a powertrax no slip for the front end.
I got my front locker installed in the carrier, and took the 30 spline shaft to see if it fit good.... Ohhhh 30 splines shafts don't fit in the 28 spline carriers. Ugh .... (Didn't know this)
Checked the OD and ID of the 30 spline carrier that the locker came in, and it's the same OD as the 28 spline carrier, they just drilled it out more. So I figured what the heck, some grinding is easier than shimming gears.
28 spline carrier
30 spline carrier
Precision milling device....
Carrier in and the shafts slid in no problem :)
Old April 7th, 2014, 08:35 PM   #337
Deuling
Sand Slut
Deuling's Avatar
Hello :D
There goes 2 weeks + of paychecks lol
Old April 7th, 2014, 08:36 PM   #338
Deuling
Sand Slut
Deuling's Avatar
Axle fun :D
Some rust converter and set the perches on for a look...
Cleaning the inside
Old April 7th, 2014, 08:38 PM   #339
Deuling
Sand Slut
Deuling's Avatar
Swapping 6 lug stuff from an 89 axle into the 82 8 lug housing. (the 6 lug housing was too rotted, the tubes were leaking gear oil!!!) 6 lug shafts are about 1/2" longer so the backing plates need to be moved out about a 1/2".
So I drew up some spacers and had them cut out of stainless at work. 2 different thicknesses so I can get them just right. 11ga and 18 ga.
Dad was bored the other night so he did the measuring..
And I drew them up on break today.
Old April 10th, 2014, 09:42 PM   #340
Deuling
Sand Slut
Deuling's Avatar
Test fit, work perfect. Really nice tight fit.
Tags
k5, silver lake
Page generated in 0.32879 seconds with 85 queries
