Deulings' dune runner K5 - Page 15 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 15th, 2013, 06:36 PM   #281
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Originally Posted by Deuling View Post
2 new stickers. Ord and sidetracked offroad
Those are some badass stickers!
Old June 15th, 2013, 06:52 PM   #282
GREASYHANDS
GREASYHANDS's Avatar
Extra HP right thur
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 15th, 2013, 11:54 PM   #283
Deuling
Sand Slut
Deuling's Avatar
Deuling is offline   Reply With Quote
Old June 16th, 2013, 01:20 AM   #284
Badass brackets aren't needed for chatter bumps FYI.
Old June 16th, 2013, 04:43 AM   #285
curbdog17
Mini Van
curbdog17's Avatar
I thinks he is going to end up driving this thing much faster than he plans.
Old June 16th, 2013, 04:49 AM   #286
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
If your springs are made for 12" of travel, why is the 6" bumpstop set so that it is on top of the spring??? Wouldn't that limit your springs to +/- 8-9" depending on droop????
Cheap Thrills Off Road
Old June 16th, 2013, 07:50 AM   #287
Deuling
Sand Slut
Deuling's Avatar
Those are 4" bump stops
And I set them for 5.5" of up travel just to be on the safe side of things. 1.5" between the pads in those pics.
Old June 16th, 2013, 12:59 PM   #288
BigBird
BigBird's Avatar
Ok, poor camera angle... My mistake, please continue.
Old June 16th, 2013, 01:08 PM   #289
shortiron
Oh yeah forgot to give you some shortiron fab stickers, better pick some up.
shortiron is offline   Reply With Quote
Old June 16th, 2013, 02:56 PM   #290
ATVLIFESTYLE
ATVLIFESTYLE's Avatar
Did you break down your springs to determine bump height? Also you are going to want to make sure the ubolts arent sticking up past what you are bumping off of. Make sure you are giving yourself pleanty of space to bump off, you wont aleays bump off an exact location with leafsprings. Just my first thoughts looking at it.
ATVLIFESTYLE is offline   Reply With Quote
Old June 16th, 2013, 03:20 PM   #291
Deuling
Sand Slut
Deuling's Avatar
Yes that was the reason. And to make sure stuff wasn't going to hit and interfere etc.
Had to clearance cv stops and was able to get an exact measurement of what my driveshaft needs to be for length and slip.
And yes I mounted the bumps where at full bump they will be at the one side of the pad, and when they hit they will be on the other. You can see they are off centered from the pads
The shackle moves the axle just about an inch back on bump travel
Old June 16th, 2013, 03:39 PM   #292
ATVLIFESTYLE
I'm not bagging on you just an observation when I look at the pics. hard to tell and alot of people don't take into account that you need a generous area to bump off of for a Leaf setup like that. It will not bump off the exact location every time like a linked setup. It will move side to side and front to back based on the situation which can cause poor handling charecteristics, and possibly bent parts.
I also wouldn't bump off the factory Ubolt plate if you aren't going to run a swaybar and don't need it. Or at least add a plate to the top so the cast piece isn't taking the direct hit and the rounded edges are gone.
I know because I have setup a few and haven't always been spot on even with proper cycling. It's just my 2 cents so take it for what you think its worth.
Old June 16th, 2013, 03:41 PM   #293
Deuling
Sand Slut
Deuling's Avatar
I may make a plate... Little late though now to add more material though lol.
Old June 23rd, 2013, 05:03 PM   #294
Deuling
Sand Slut
Deuling's Avatar
Old June 23rd, 2013, 09:14 PM   #295
Deuling
Sand Slut
Deuling's Avatar
Originally Posted by deerebowtie View Post
so when is some actual building going to commence? you pimp this thing hard enough someone might expect some real quality fabrication, not kendravsmichigan
I mean shit, where's the air freshener update?
Huh?
Old June 25th, 2013, 12:39 PM   #296
dreezy
Haggard Fab
dreezy's Avatar
Does this mean you will be at the doons with it this weekend? I'd really love to watch it tear up some chatter bumps.
Old June 27th, 2013, 11:16 AM   #297
Deuling
Sand Slut
Deuling's Avatar
I caved
Old June 27th, 2013, 11:40 AM   #298
curbdog17
Mini Van
curbdog17's Avatar
Bling Bling
Old June 27th, 2013, 11:44 AM   #299
Deuling
Sand Slut
Deuling's Avatar
Originally Posted by curbdog17 View Post
Bling Bling
You guys convinced me. That 4th stud should make me not worried of running any bus full of nuns off the road lol.
And that's all of last weeks paycheck
Old June 28th, 2013, 07:08 PM   #300
shortiron
I've seen bigger
Tags
k5, silver lake
Page generated in 0.46952 seconds with 84 queries
