88-98 GMC parking brake cable diagram? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2013, 04:27 PM   #1
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Default 88-98 GMC parking brake cable diagram?
I'm trying to piece back together the parking brake cables on my 94 GMC 2500, and I'm thinking I'm missing some parts. Unfortunately I don't have any sort of book yet. Google only yeilds stuff from the 1960's and older, or just pictures of the new cables coiled up as they come packaged.
How exactly does the Passenger rear brake cable attach to the front cable? Could somebody post a quick picture of one maybe?
1994 GMC 2500
extended cab, 141" wheelbase
6 lug
Old January 23rd, 2013, 12:16 PM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Step 1- got to auto parts store
Step 2- fine Haynes manuals
Step 3- browse related manuals for your truck
Step 4- look at or take picture of parking break diagram
Step 5- look at picture or print out to solve problem
I know, not exactally helpfull, but it's a lot better than someone explaining it to you
edit: and to answer your question there is a screw tensioner that is meant to attach both pass and drivers side cables to the cable heading up front. If you would like, i can take a picture of the one on my truck later today and post it up
Old January 25th, 2013, 10:08 AM   #3
Captain Ledd
Ranger Addiction?
Well I think I have figured it out after much searching and asking.
I ended up needing new everything except the actual pedal assembly, and my "eaqualizer bracket" as they call it was missing the threaded screw on the end, but wasn't all bent up so I thought it was good.
So, I go to Napa because they can actually order ALL the cables I need, the first set, the front cable was incorrect, as was the driver side rear. I assumed the passenger rear would also be incorrect, more on that later.
So they ordered cables for a 1/2 ton. Front cable fit great, as did the drivers side rear, this passenger rear didn't have that threaded rod on it and was that pressed block end and I was racking my brain trying to figure out how it attached or which one was the correct one. Turns out the first Pass/rear cable was the correct one in the first place after I had found a picture of the Equalizer bracket (and the threaded end which wasn't on mine) basically by mistake browsing through photo's trying to figure stuff out.
As of right now I think I have it right, it kinda works, but I have more adjustment left to it. I'm hoping over the weekend I can tighten things up and it'll work as it should.
I know I should get a manual on this, but money is tight and I need to cut where I can, I had assumed I was mechanically inclined enough to figure it all out on my own. All of this work got kicked off because it popped a brake line. I can deal with some other issues on the truck, but I don't want to go through that again.
Page generated in 0.14910 seconds with 32 queries
