Sub box help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2013, 10:43 AM   #1
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Default Sub box help
I'm rebuilding my box yet again. Going from 2 12s to 3
Would it be better to build a one chamber box not ported for all 3 or a 3 chamber box, one for each sub, also not vented.
Btw this is a truck box so its small chambers.
I would assume 1 would be best being that the cu ft is under factory recommendation?
Old January 19th, 2013, 11:04 AM   #2
bdd1469
bdd
bdd1469's Avatar
I like seperate boxes when ever possible. I think you get a better sound when several drivers arn't competing for the same air space. Just my personal thoughts.
If you are working with a small area consider building out of fiberglass and just using mdf where your drivers mount. You can use every inch of available space by building with glass.
Old January 19th, 2013, 11:22 AM   #3
bdd1469
bdd
bdd1469's Avatar
Old January 19th, 2013, 11:56 AM   #4
92FleXj
92FleXj's Avatar
My only though ( which may be wrong)
If the sub req 2cu ft min. If I do single chambers it will be, say 1.5 each. if I did one single it would be 4.5 cu ft. I just don't know what would sound better.
Old January 19th, 2013, 12:18 PM   #5
ajmorell
I'd separate them
Sent from my DROID BIONIC using Tapatalk 2
Old January 19th, 2013, 12:18 PM   #6
caveman
GeoDude
caveman's Avatar
From my experience single chambers and if you can't give them what they want don't waste your time. two with the correct space will sound/perform better than three with incorrect.
Old January 19th, 2013, 12:25 PM   #7
drew454u
drew454u's Avatar
This x2.
A properly setup 1 woofer system can out perform a multiple woofer system that isn't setup properly.
drew454u is offline   Reply With Quote
Old January 19th, 2013, 12:51 PM   #8
caveman
GeoDude
caveman's Avatar
Originally Posted by drew454u View Post
This x2.
Old January 19th, 2013, 01:24 PM   #9
montecarlo33
The Violator
montecarlo33's Avatar
With them all sharing the same air space they will "choke" each other out unless you have a pretty large port, with seperated parts to the box each sub can have their own airspace which IMO gives a cleaner/tighter sound.
Old January 19th, 2013, 02:35 PM   #10
92FleXj
92FleXj's Avatar
Good to know. I will get the min specs and see if I am within them. I have to add up what my box is first than ill know if I have room.
Old January 19th, 2013, 05:12 PM   #11
muddinman56
blood,sweat and beers
muddinman56's Avatar
this
Old January 19th, 2013, 07:37 PM   #12
skife
skife's Avatar
when does it not matter how much bass you have?
Old January 19th, 2013, 07:43 PM   #13
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
If you're doing 3 12's, have you considered instead of {ooo}, making it {o0o}? It would make it more of a triangle design, but you would create a lot more airspace.
Old January 19th, 2013, 08:48 PM   #14
stereoguy
2jz NO SH*T!
stereoguy's Avatar
This man has it right! I have not seen a under boxed setup that would out perform a lesser number of correct volume subs.
stereoguy is offline   Reply With Quote
Old January 26th, 2013, 07:55 PM   #15
92FleXj
92FleXj's Avatar
.88 is min cu ft for a non vented box, so i should be good
Old February 9th, 2013, 11:20 AM   #16
92FleXj
92FleXj's Avatar
What does filling the box with cotton do? I see this alot.
Old February 9th, 2013, 11:25 AM   #17
montecarlo33
The Violator
slows down the sound waves if I remeber right. Dont need much, I went overboard back in the day with bad results. Also if you have it ported it will probley come out anyways, mine did and I was always restuffing it back in. IMO you want that for a sealed box.
Old February 9th, 2013, 12:40 PM   #18
snboarder113
snboarder113's Avatar
You can trick the woofers with poly fill to make up for the lack of space. In a sealed box. If this is going in a truck, you want a sealed box
snboarder113 is offline   Reply With Quote
Old February 9th, 2013, 01:49 PM   #19
firehawk
Live Action!
firehawk's Avatar
Boom Boom!
Old February 9th, 2013, 01:54 PM   #20
Wehan
Wehan's Avatar
Definatly seperate chambers. Also if your 2 12s arent cutting it for ya you can get nice results out of 4 10s with proper box and easier to fit them in a truck. Ive even listened to an s-10 with 8 infinity reference 8s that suprised the hell out of me!
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Page generated in 0.32980 seconds with 82 queries
