WINCH from Harbor Freight? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2013, 08:27 AM   #1
jimhri
jimhri's Avatar
Default WINCH from Harbor Freight?
12,000# winch for 300.00 and confirmed that Off-Road Magazine said it was a great deal and worthy.
http://www.off-roadweb.com/tech/1112...l_in_winching/
any comments?
would adding a winch require a new, higher amp battery???????
jimhri is offline   Reply With Quote
Old January 19th, 2013, 08:29 AM   #2
firehawk
Live Action!
firehawk's Avatar
I have one.
In the box in the back seat of my truck.
All I know so far is its heavy.
Old January 19th, 2013, 08:30 AM   #3
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
The old bad thing I've heard 'bout em is they're pretty slow; other than that, should be a good tool.
concreteguy82 is offline   Reply With Quote
Old January 19th, 2013, 08:33 AM   #4
92FleXj
stacks stacked on stacks
92FleXj's Avatar
I'm thinking of buying one to put on my trailer.
Old January 19th, 2013, 08:54 AM   #5
bdd1469
bdd
bdd1469's Avatar
A winch will benifit from a bigger battery but it not ususlly required. Make sure all of your battery cables have good connections, and are large enough. When you are pulling hard a winch will pull a lot of amps and kill any battery in a hurry. The best thing you can do is a series of short pulls with a few min in between to let the winch cool and batt charge.
When using your winch stop after a few min and relax the cable. Touch the winch motor and battery cables carefully. They should get warm, if they get too hot to touch you need more battery, better connections, or both. A winchs worst enemy is heat.
I have been very impressed with the harbor freight winches that I have seen. Slow, but reliable.
Old January 19th, 2013, 09:05 AM   #6
jimhri
jimhri's Avatar
thank you bdd1469 &
ttt
Old January 19th, 2013, 11:35 AM   #7
If you are planning on using it for the occasional recovery, that winch and a stock battery will be fine. If you're wanting to do more hardcore stuff where you will be winching alot, neither that winch or a stock battery are the best.
Old January 19th, 2013, 11:41 AM   #8
kkodet
kkodet's Avatar
I've got that same winch on a reciever I use in on my trailer and my Cherokee. I like it a lot better than my old Chicago electric. It is faster and better built IMO.
Like Whiter Hino said, it's good for the occasional stuff.
Old January 26th, 2013, 07:38 AM   #9
jimhri
jimhri's Avatar
Default winch impacts suspension?
the harbor freight 12000# winch and rough country mounting plate weigh approx 100#. this is on the front stock bumper which is of course forward to the front wheels.
what impact will this added weight/location have on the TJ drivability? the TJ is currently garaged for the season so no test drive is in the plans. have stock front suspension with 2" budget boost.
seeing as everything is always attached to something else,........should i consider different coil springs, stronger shocks or anything else?
FYI
the harbor freight "universal" mounting plate is NOT universal to the TJ stock bumper. requires drilling of 1/4 inch steel, etc.
instead i ordered and installed, without any adjustment, the rough country TJ front bumper mounting plate [piece #1189....
http://www.roughcountry.com/winch_mounts_jeep.html]
only change i made was using grade 8 bolts to hold the tow hooks and stock bumper to the frame.
Page generated in 0.33021 seconds with 50 queries
