computer question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2013, 11:44 PM   #1
muddinman56
blood,sweat and beers
muddinman56's Avatar
Default computer question
what do i need to hook my laptop up to my tv?
i have a spare flat screen and was wondering how i could hook them together?
Old January 19th, 2013, 12:42 AM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
First, make sure your laptop has an output for a second monitor. Depending on the age of the laptop it may have a VGA, HDMI, both, or none at all.
Next make sure your TV has a matching input available. Most HD sets will have a VGA input, all will have HDMI.
Then all you need is the video cable of appropriate length and a 3.5mm to rca adapter cable for sound (only needed with VGA).
Once the connections are made the laptop may detect the tv and prompt you to make selections on how to utilize the new screen. If it does detect the tv, you'll have to change the display settings manually.
Some laptops are super simple, my 6 month old Toshiba auto-detected the TV right away and turns the laptop screen off when the tv is plugged in. (My preference for video streaming) My wife's 3 year old sony took about an hour to get the laptop to see the tv as a screen option and get the settings to work properly.
TIP: you may have to also change the screen resolution settings for the tv to display the image properly or at all for that matter. Our older Samsung plasma will only see a pc as an input if the resolution falls into a certain parameter.
Buy cables from monoprice.com, I had less than $20 into a 25' VGA cable and audio cable shipped when I did mine.
NOT sent from an iPhone
Old January 19th, 2013, 05:17 PM   #3
muddinman56
i have like a 2 year old gayway craptop its not a bad laptop but its like 2 steps about bear bones
this port has a little picture of a tv right next to it.
does wally world or mijer have this cable ?
well that plug to hdmi?
Old January 19th, 2013, 05:57 PM   #4
BlooMule
Old School
BlooMule's Avatar
PC output, tv will need PC input, and you need the cable
-rw-rw-rw
BlooMule is online now   Reply With Quote
Old January 19th, 2013, 06:03 PM   #5
bigblockford79
Big Block Ranger
That is a VGA connection, which is video only. As far as I know it won't adapt to hdmi so your tv will need to have the same connection. Those stores may have a short one, but not likely anything over the standard length. Best buy should have what you need but it won't be cheap.
Old January 19th, 2013, 07:35 PM   #6
skife
skife's Avatar
monoprice.com has cheap cables.
http://www.monoprice.com/products/pr...seq=1&format=2
ten footer is like $4 and change.
Old January 19th, 2013, 08:27 PM   #7
firestorm
If you have a VGA input on the TV, you can use a VGA cable like skife linked to and just use a 3.5mm stereo to RCA stereo cable to connect the headphone output on the laptop to an RCA stereo input on the TV.
Example:
In a lot of ways, VGA is easier to get working properly vs. HDMI. VGA is just more accepting of PC resolutions. HDMI sometimes gets pissy if your computer doesn't send a standard TV resolution.
Monoprice is awesome BTW. They are not junk cables by any means. Great TV mounts as well.
firestorm is offline   Reply With Quote
Page generated in 0.24815 seconds with 43 queries
