1997 powerstroke **sold** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2013, 05:13 PM   #1
Default 1997 powerstroke **sold**
1997 F250 crew cab short box 4wd auto xlt package. 7.3L powerstroke. Approx. 260k Class 3 hitch w/ brake controller. Also has goose neck rails in box (hitches not available)$5000
Has rust starting in bottom of doors, and bottom LF fender. Bubbles forming around box wheel wells. Rockers and cab corners almost 100% rust free. Lite damage to bottom pass drs and rocker. Does not effect weather sealing and does not create cab noise-see pics
MANY newer parts. Anything that was ever in question was replaced, truck always needed to be ready and reliable for hauling. Ase master mechanic owned. Truck was primarily used for towing single car trailer. Rides, drives, runs, and tows nice. Looking to upgrade to a box type truck for enclosed hauling. In no means does it have to sell. If i buy a enclosed car hauler before this sells it will be coming off the market.
Water pump (10,000 miles ago)
Serp. Belt (1,000 miles ago)
Two new batteries last week
Glow plugs (motorcraft plugs 10,000 miles ago)
Replaced valve cover gaskets and under cover harness's at glow plug replacement
Oil change about 400 miles ago
Trans is freshly serviced and replace the torque converter 8,000 miles ago
Replace the turbo up pipe collector and gaskets, removed the ebv from the turbo pedestal at the time of the converter replacement
Mechincal fuel pump 5,000 miles ago
Has a MPRB downpipe from turbo and straight 4" pipe out past the rear axle (not loud but has a good tone and slight whistle from turbo I installed a pyro to monitor egt's when towing and also has a boost gauge.
Truck has never had a tuner on it.
Front fuel tank and straps replaced last year
Earlier this past summer replaced front rotors/calipers/hoses and brake lines in the front and repacked the wheel bearings
Has coil overload shocks in the rear
Multiple sensors have been replaced over the last two years-IPR ICP, CKPS etc...
Tie rods and ball joints all MOOG
Tires are 265/75-16 MAstercraft AT2 Load range E
When I purchased the truck I removed the forward valve body in the trans and replaced the springs to increase line pressure to better the trans shifting and reduce heat. It Does not shift hard. Protects the trans better when towing.
Also new postive battery cables (motorcraft replacement)
ID:	100764   Click image for larger version
CheapThrillB2 is offline
Old January 18th, 2013, 05:15 PM   #2
BIG Ben
Stay thirsty my friends..
BIG Ben's Avatar
How much?
BIG Ben is offline
Old January 18th, 2013, 05:38 PM   #3
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Originally Posted by BIG Ben View Post
How much?
I'm going to guess 5000.00
92FleXj is offline
Old January 18th, 2013, 05:47 PM   #4
firehawk
Live Action!
firehawk's Avatar
You are a genius!
firehawk is offline
Old January 18th, 2013, 05:49 PM   #5
BIG Ben
BIG Ben's Avatar
Was not posted when I asked.
BIG Ben is offline
Old January 18th, 2013, 05:51 PM   #6
92FleXj
92FleXj's Avatar
You are a genius!
That was a damn good guess. I'm going to get lotto
92FleXj is offline
Old January 18th, 2013, 05:55 PM   #7
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Nice truck. If I could sell mine, I'd defiantly check it out.
MonkeyBiz is offline
Old January 31st, 2013, 06:05 PM   #8
Old February 2nd, 2013, 12:19 AM   #9
chasetheface123
chasetheface123's Avatar
Trades?
chasetheface123 is offline
Page generated in 0.21667 seconds with 51 queries
