Chrysler RB1 radio with extra - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2013, 10:26 AM   #1
Dylan
Dylan's Avatar
Default Chrysler RB1 radio with extra
I have an RB1 chrysler radio for sale. It come with nav DVD and an xm direct box that can be used for aux in though rca cables. I also have an xm receiver module (no subscription) and I believe it also has the factory splitter to run the xm with a factory cd changer if you have one. This works for most chrysler products up to 2007. It will fit the older jeeps as well (obd2 with PCI 1999-2002) as I have the factory pigtail adapter as well. You will need a can wire from the obd2 port ran to the pigtail. The can is only used to tell the nav when you are in reverse so it doesn't flip your arrow around, and used to tell what radio what vehicle it is in to switch the boot up screen.
If this is put into the older jeep (99-2002) the bezel will need to trimmed and the mound will need to be cut a bit. Basically if you have the radio with square corners you will need to make it fit but the wires are there. If you have a jeep with the round corners than it will drop right in and again plug right in.
Asking $550 for everything. Here are some stock photos of the stuff. Everything is like new.
here is the kit without the extras new http://www.acmejeepparts.com/products/96083_2000.htm
If you have a 2001 Tj with a clean center bezel, we can probably work out something to swap so you don't have to cut yours out. I cut mine exact and its perfect. It looks all stock and no one can tell unless I point it out.
Located in Kalamazoo.
Edit: Here are some pics of the actual radio. You can see the difference between mine (2001) and the first pic. Closeup of the cuts also.
Old January 18th, 2013, 11:59 AM   #2
Dylan
Dylan's Avatar
holly crap 5 pages in one day lol. Bump
Page generated in 0.20063 seconds with 29 queries
