two K5's '84 & "90, 3" lift *updated 1/23/13* - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old January 17th, 2013, 08:41 AM   #1
swampjeep
Swamp Stomper
swampjeep's Avatar
Default two K5's '84 & "90, 3" lift *updated 1/23/13*
I have 2 k5's that will be going to the scrap yard soon
*update*someone is buying the complete 90
I believe he plans to part out:
-axles, which are 3.73 gears if still factory
-top which has the side vent windows.
-front clip
-class iii hitch $50
-radiator
remaining set axles,
will need to check gears (code was like GQU8 standard)
$200 complete set
3" lift that was put on a few years ago, but truck has sat ever since,
only driving a couple times with new lift (front springs, rear blocks, 4 shocks)
$200 you remove or
$300 I remove
700r4 - $100
NP208 - $75
one set doors from FL truck, manual windows $100
one front clip from AZ truck, still assembled, with excellent core support, fenders good, but need minor body work (small bent, 1 spot rust, bottom curled slightly)
($200 obo)
2 tops $50 each 1 white 1 black
let me know what parts you are looking for
I'm looking for:
set of aluminum rims, 5x4.5 8-10 wide
K5 with good body, roller OK, I have drive train
swampjeep is offline   Reply With Quote
Old January 17th, 2013, 02:36 PM   #2
Zelda
Zelda's Avatar
Need: fuel guage harness from the firewall back to the tank.
Rear seat belts, passenger seat mounting brackets.
Zelda is offline   Reply With Quote
Old January 17th, 2013, 02:40 PM   #3
Zelda
Zelda's Avatar
Need: fuel guage harness from the firewall back to the tank off the 84.
Old January 18th, 2013, 07:40 AM   #4
swampjeep
Swamp Stomper
swampjeep's Avatar
let me check this weekend, I'm pulling the motor out of the 84, so I should be able to check out these things while I'm at it.
Old January 19th, 2013, 06:59 PM   #5
Zelda
Zelda's Avatar
Ok, great. If you have both seat brackets and there nice shape i'd take both.
Thanks!
Old February 15th, 2013, 08:32 PM   #6
michigan maniac
michigan maniac's Avatar
Pm sent
Old February 16th, 2013, 05:05 PM   #7
beck
What brand of lift? shocks?
beck is offline   Reply With Quote
Old February 21st, 2013, 07:16 PM   #8
spectreblazer
spectreblazer's Avatar
do you still have the 84 frame, axles, t-case trans?
spectreblazer is offline   Reply With Quote
Page generated in 0.21797 seconds with 47 queries
