Ford parts interchange ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2006, 11:48 AM   #1
Grandman
do i look old !
Grandman's Avatar
Default Ford parts interchange ?
Any one know right off . Does the newer 1/2 ton Ford rotors and hubs off the twin I beam front fit the older Ford 44 fronts ?
Iv got donor locke outs hubs and rotors for my project 44 if so !
while were at it are Mile Marker lock outs any good ?
Old October 27th, 2006, 11:54 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I've read of it being done. Seems that it would.
Old October 27th, 2006, 02:27 PM   #3
PavementPounder
PavementPounder's Avatar
I swapped solid D60 dually hubs with Crassel for SRW F-350 hubs from one of those D50 things and my shit fit right on. Don't know about the D44 stuff, but it sounds like they are the same.
But that would mean someone at Ford has a brain, which we know is impossible.
Old October 27th, 2006, 02:31 PM   #4
Grandman
do i look old !
Grandman's Avatar
Im guessing they will , why retool to make the outer stuff just becuase they dropped the straight axle . Guess we will find out for sure when i get back home . Ill knock the twin beam apart and see if they fit .
Figured if some one all ready tried it they could save me any wasted time .
Old October 27th, 2006, 02:32 PM   #5
Icebreaker88
Icebreaker88's Avatar
Hub and rotors are the same between IFS and solid 44. Spindles are not.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old October 28th, 2006, 01:37 PM   #6
Grandman
do i look old !
Grandman's Avatar
works for me , i have a good set of spindles , both rotors and hubs are in poor shape though .
Old October 31st, 2006, 02:35 PM   #7
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
yep all the d44 hubs are the same unless going from manual to auto hubs (vice versa) and the dredded 87-88 hat style hubs are unique to themselves as they use a shorter spindle and also short axleshaft.
mooseracing is offline   Reply With Quote
Old October 31st, 2006, 02:36 PM   #8
mooseracing
Stuck like a MoFo
D50 & D60 used the same size hubs at least up into the Super Dutys. Started with the TTB 50's.
Page generated in 0.24632 seconds with 47 queries
