1994 Bronco Locking hub question. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2013, 11:26 AM   #1
transamsam
lucky #13
transamsam's Avatar
Default 1994 Bronco Locking hub question.
I have a 1994 Bronco with the automatic locking hubs and I wanted to convert them to manual. Do I need the conversion kit along with the manual hubs to do so? I have done some research and some say you do and others say you don't need it. Just wondering your thoughts, any help would be appreciated.
Thank you
Sam
transamsam is offline   Reply With Quote
Old January 16th, 2013, 11:47 AM   #2
foxworthy1102
foxworthy1102's Avatar
Check out fullsizebronco.com you'll be able to find all the info you need for your bronc
foxworthy1102 is offline   Reply With Quote
Old January 17th, 2013, 08:31 AM   #3
transamsam
lucky #13
transamsam's Avatar
Yeah I researched it on that site, from everything I gathered since I have the 5 bolt automatic locking hubs the manual hubs should be a direct swap with no conversion kit needed.
Old January 17th, 2013, 09:12 PM   #4
Kane
Got Jeep?
Kane's Avatar
When I switched to Warn manual hubs on my F250 I called Warn direct to find out. (Didn't need 'em on mine) They where very friendly and helpful. Found the # on their website.
Kane is offline   Reply With Quote
Old January 17th, 2013, 09:15 PM   #5
TJ/WILLYS
TJ/WILLYS's Avatar
If you have the ratcheting nut,you need the conversion. You won't know unitl you remove the hub.
TJ/WILLYS is offline   Reply With Quote
Old January 18th, 2013, 06:34 PM   #6
transamsam
lucky #13
transamsam's Avatar
Yeah I just got the manual hubs and I will see how it all works out on Sunday.
Page generated in 0.16672 seconds with 41 queries
