2.5 ton axle shaft question - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2013, 06:20 PM   #41
92FleXj
stacks stacked on stacks
92FleXj's Avatar
How old are you?
Old January 21st, 2013, 06:21 PM   #42
cj65
cj65's Avatar
Originally Posted by cerial View Post
7" shaft from the 2wd sm465 to the aux trans then another 7" shaft from the aux trans to the transfer case. It lets me remove the aux trans if it needs to be rebuilt/replaced and continue driving with the 2.68, 1.27, .75 ratios by using a single shaft.
It is a rare aux transmission so if it goes parts are going to need to be machined. It came out of a dump truck then was completely rebuilt then ran for 3k before I got it so I should be good. Still. it is good to plan for when stuff happens then be screwed and need to rent a uhaul to get back home(been there).
Throw it away and just use what's proven to work. Why be different ? It's all added weight with no advantage. Ahhh fukc it it's your cash do what you want.
Old January 21st, 2013, 06:24 PM   #43
92FleXj
92FleXj's Avatar
Judging by it all being 40 or 50 year old parts I'm assuming all this junk was free..
And if like to see some updated on the ups truck with a roll cage build thread as well. It's been kinda quiet..
Old January 21st, 2013, 06:51 PM   #44
benny87
Young Gun..!
benny87's Avatar
I wanna drink bleach just from reading this...:banghead:
benny87 is offline   Reply With Quote
Old January 21st, 2013, 08:33 PM   #45
Suta99
Suta99's Avatar
You say it's gonna stay around 4500lbs and your rocking 1000lbs of rims and tires on rockwells. Your half way there already.
Old January 21st, 2013, 08:52 PM   #46
hamsmotorsports
hamsmotorsports's Avatar
Big block caddy,two transmissions, transfercase, four drive shafts, rocks with wheel brakes,40's, double welded chassis, custom watts link suspension. I'll be suprised if it is under 6000 lbs.
hamsmotorsports is offline   Reply With Quote
Old January 22nd, 2013, 06:30 AM   #47
Suta99
Suta99's Avatar
My exo'd 80 toyota pickup with 37's weights just over 4300 lbs. that's narrow toyota axles, 4 cyl diesel, and a extra transfer case.
Page generated in 0.28463 seconds with 44 queries
