97 xj lifted d44/60 4500$ trade for other jeep or truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2013, 12:58 AM   #1
vteckickin
Default 97 xj lifted d44/60 4500$ trade for other jeep or truck
I have a 1997 Cherokee with 201xxx miles on the body, motor has been replaced with a lower milage 4.0, solid AW4 auto trans, NP231J with a fresh HD SYE with less than 10 miles. Jeep has very little rust, small spot on rear hatch. floors are solid and drivers rocker has a small hle underneath and the passenger side is solid.
Rear axle is a Ford D60 with disc brakes. Has Ruff Stuff anti wrap spring perches and the brakes are basically brand new. It is also welded and has 3.55 gears
Front axle is a Ford HP D44. It has a tie rod made of 1.5x.25 com that is over the knuckle with 3/4 heims. the axles has a truss for the upper link and hydro assist mount. The axle uses ballistic fab mounts with fully captured coils, double shear shock mounts. the lowerlink mounts have skids underneith. There is a draglink also made of 1.5x.25 with 3/4 heims and is bent at the box to be parrell with the ground. The axle has less then 300 miles since new ball joints, ujoints, calipers, rotors, spindle bearings. all bearings are timkn and seals are National. the pinion seal is a little leak but have a national nib. wheen rebuilt the brake brackets and knuckles were media blasted and painted with self etching primer. The whole axle has been wire wheeled and primed as well then all shot with flat black paint. The diff cover has been plated with 3/16ths and 1/8th. I have extra brake hardware and set of shafts. The axle has Warn Premium lock outs it has 3.55 gears and a welded carrier.
Track bar is 1.5" DOM with heims and has HD bracket.
Rear suspension is RE 4.5" leaf springs with 1" Currie HD shackles and 2" block
Front is a custom built 3 link with 2x.25 DOM lowers and 7/8x3/4 heims and 1.5x.25 DOM upper on drivers side with 3/4x3/4 heims. Uses 5.5" RE coils. Also a really nicely built custom HD crossmember
Tires are 35x12.50x16.5 BFG MT will need balanced
coils or shocks make nose when u hit bumps
the 3link bar has to long of a bolt in it an the ds hits when flexing
The jeep runs great and flexes awesome.
Also has a JCR steering box spacer with a newer steering box.
TNT unibody stiffeners.
All the brake lines are brand new.
can text better pics
Cash price is $4500 OBO
http://www.greatlakes4x4.com/attachm...0&d=1340948277
http://www.greatlakes4x4.com/attachm...9&d=1340948261
http://www.greatlakes4x4.com/attachm...2&d=1340948308
http://www.greatlakes4x4.com/attachm...3&d=1340948558
vteckickin is offline   Reply With Quote
Old January 16th, 2013, 04:17 AM   #2
mud_digger
mud_digger's Avatar
Already?
mud_digger is offline   Reply With Quote
Old January 16th, 2013, 11:51 AM   #3
vteckickin
well i have a deal on the truck i want and if i can get the car or jeep thay want and swap them then il do it i like the jeep alot tho
Old January 16th, 2013, 01:28 PM   #4
mud_digger
mud_digger's Avatar
What truck ya looking at
Old January 16th, 2013, 01:46 PM   #5
vteckickin
04 hd
Old January 16th, 2013, 03:54 PM   #6
mud_digger
mud_digger's Avatar
Nice
Old January 16th, 2013, 07:18 PM   #7
vteckickin
still lookin
Old January 16th, 2013, 08:58 PM   #8
tubes92
tubes92's Avatar
I want this!!
tubes92 is offline   Reply With Quote
Old January 17th, 2013, 08:05 AM   #9
Seraphim Soldier
Always the hard way
Seraphim Soldier's Avatar
Partial trade?
2000 Wrangler F%&*$#@ CHEAP. - Great Lakes 4x4. The largest offroad forum in the Midwest
Seraphim Soldier is offline   Reply With Quote
Old January 17th, 2013, 06:21 PM   #10
vteckickin
make offers will look at anything
Old January 20th, 2013, 03:16 PM   #11
vteckickin
make offers looking for a truck
Old January 20th, 2013, 07:44 PM   #12
vteckickin
sale pending
Old January 23rd, 2013, 10:05 PM   #13
vteckickin
gone
Old January 23rd, 2013, 10:07 PM   #14
mud_digger
mud_digger's Avatar
What ya get?
Page generated in 0.25829 seconds with 66 queries
