4.3 help no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2013, 09:01 AM   #1
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Default 4.3 help no start
I just bought a 94 s10 blazer for a donor engine swap for my 4runner. The engine is a jasper reman and was running perfect about a month ago the fuel spider has been replaced recently also . I went to pick it up and it will not fire just cranks . I tried starting fluid in the throttle body and still nothing . It has only been driven in and out of the garage for about a year and normally starts right up . I have no experience with the 4.3 so any ideas ? I was thinking rotor and cap ? It has some spark when i cranked it with plug wire off to ground. I need to get this home and start tuning it up before pulling it so any ideas where to start?
stereoguy is offline   Reply With Quote
Old January 14th, 2013, 09:13 AM   #2
gmotox
gmotox's Avatar
I had this happen on a 93 4.3 truck..
1: Check coil, I replaced mine and the new was bad too :) (turned out to be the whole problem)
2: Ignition module
3: cap and rotor
Old January 14th, 2013, 09:03 PM   #3
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Thanks! Im going to try the cap and rotor first . I just didn't know where to start .
Old January 14th, 2013, 09:18 PM   #4
Jeep ZJ
Jeep ZJ's Avatar
had the same thing happen to me. check the cap and rotor.
Old January 14th, 2013, 09:47 PM   #5
beedle4
beedle4's Avatar
x2 seems like the older ones were affected by moisture easy.
Old January 15th, 2013, 05:58 AM   #6
RADRICK
RADRICK's Avatar
If you need to just get it running, you can try sanding/clean corrosion off the contacts in the cap. Also check the coil tower & coil wire for any signs of corrosion. Also for the love of god dont buy a Vato Zone cap & rotor
Page generated in 0.27254 seconds with 41 queries
